Ping Problem
Help!
I have the Ping sensor connected to an Arduino Uno Board and am trying to run the standard example program.
I've verified that the pin (7) works, but tried changing to others with similar problem.
I get a reading of 0 distance at all times.
If I disconnect the power and Gnd connections and leave the Sig connected to the digital pin I start seeing readings in the 35 to 45 cm range. I get the same result if I plug the power terminal from the Ping into pin 7. As soon as I connect sig to pin 7 and either ground to ground on the board or voltage to V5, or both, the distance reading drops to zero again.
I've tried upping the low signal duration from 2 to 5, 10 and 20 with no difference.
Is this sensor a brick or am I doing something wrong?
http://arduino.cc/en/Tutorial/Ping/
Given the number of Arduino/Sensor threads lately, should there be a new Sub Category under sensors, or just let the learn.parallax.com take care of it. www.learn.parallax.com is not well published.
Jim
Do you have a picture of you setup? That would help.
In looking at other threads I noticed the LED being referenced. My Ping LED is not lighting up at all.
I've tried changing to several other pins with no success (yes, I changed the pin in the code too).
Sound like the PING is not getting 5V power? What kind of wires/ connectors are you using?
I don't have a way to post a pic, but my setup duplicates the diagram from the arduino example linked earlier. No doubt about that.
Not saying I'm infallible, but I am an engineer and have been building computers since the 80's. This is just my first rodeo with these microprocessor/sensors. As you say, it's hard to go wrong with a 3 wire rig.
I'm guessing the first sensor was DOA, not sure what's going on with the second. I'm not near my usual bench so access to tools/meters etc is limited.
Thanks for your help so far, and I have to say that i love the hovercrafts. Something I've always wanted to do.
http://learn.parallax.com/KickStart/28015
Jim
