Crystal-Pin Socket Part Number?
Maybe this has been asked before, but I could not find details via a forum search.
My question is:
What is the part number and supplier for the Crystal-Pin Sockets used on some of the Parallax Propeller products (e.g., the Propeller USB Protoboard)?
I have received some information via similar email requests, but received not enough info to order the correct part. In my attempts, I have purchased several groups of vendor parts that appear similar, but the part is so small that published ordering details are misleading.
If available, I would like the Part Number and Supplier.
Or, it would be nice if Parallax would ADD the socket to their list of available purchase parts. I know, it is not a hot item, . . . and not many people would buy them, but I would.
My Goal is to use the Pin Sockets to support additional small devices on the Protoboard. See:
Eldon - WA0UWH
My question is:
http://wa0uwh.blogspot.com/2012/03/prop-tcvcxo-pcb.html
and
http://wa0uwh.blogspot.com/search/label/TCVCXO
and
Eldon - WA0UWH
These also come in strips of 40 that can be cut with 2 or more together or cut individually. But by the time you finish, the plastic is often go and you have lots of individual pin sockets.
Your suggestion is what I have used in the past. But I am looking for something that is still shorter and with a smaller profile that (necessarily) supports a smaller pin.
Here is one of many types that I have purchased, but it is still not the same.
http://goo.gl/qTwQ
I would really like to get the exact part.
Again, Thanks
Eldon - WA0UWH
http://www.mouser.com/Interconnects/Terminals/_/N-5g5uZscv7?P=1z0xbzaZ1z0j54tZ1yzxc0hZ1z0z2tk
After comparing your suggested part specs with physical measurements of the actual part on the Propeller USB Protoboard, it appears that the H3153-05 maybe a very close match - This part is so small, that it is difficult to know for sure.
I now have several of these on order.
http://goo.gl/NrRrf
Again, Thanks
Eldon
