Consulting the crystal ball: What comes after the Prop2? — Parallax Forums
markaericmarkaeric Posts: 282
edited 2012-06-20 02:17 in Propeller 1
First of all, it's great to be back again. I wish I could say that I travelled around the world, or been abducted by aliens but unfortunately that wasn't the case. Besides that, I've been spending the past several days finishing up a propeller project where I left off about a year ago, which I hope to share with you all soon.
Anyway, I've read the progress made on the P2, and it looks like it's going to be quite a beast. So beastly in fact, that I don't understand half the features! It's intimidating to say the least. Now, I know it's almost blasphemy to talk about a follow up to a product that hasn't even been released yet, but bear in mind I intend that this discussion is only in good fun, so please don't demand my head on a platter! :)
Of course, the natural assumption is that the next silicon after the P2 would be a bigger and badder P3 (that is, if Chip isn't sick of making processors by then, and instead picks up gardening), but I would actually like to sort of see the opposite. If you didn't already want to see my head roll, I'm sure you do now, but hear me out. I think there is a comfy spot in between the P1 and the P2, which I'll refer to as the P1.5. Nothing too fancy, but a few modest upgrades. In a perfect world where we could all get what we want, here would be the things that I would want:
Essentially a good ol' P1 manufactured on a smaller process. This would allow for a higher clock speed, and a bunch more hub ram.
64 P1-esque GPIO
one or two 32-bit SERDES per cog with clock generation/capture
Upgraded video engines - up to 16-bit color VGA/composite
inter-cog comm port like on the P2, maybe wider
A shared single cycle math engine similar to that on the P2 accessible via the hub, or more preferably it's own hub out of phase with the memory hub (so you don't have to choose between memory or math engine access). Possibly with programmable bandwidth.
And possibly the much hated programmable hub bandwidth.
That's my happy medium. Now if I could only sell a billion propeller-based products, maybe I could convince Parallax to make my custom chip! :)
    edited 2012-06-17 06:38
    Part of the problem is that P1 was designed with tools that don't scale to different processes. Much of the work building P2 has involved moving to design tools that facilitate design automation. So if P3 is anything, it's likely to be a modified P2. At some point either Ken or Chip mentioned that it would just be a matter of throwing money at the fabs to get P2 scaled to a 45 nm process that would run at 1 GHz. (It would also dissipate a hundred watts at rest due to barrier leakage at the smaller geometry.)
    I think there is a definite place in the market for P1.5 on the low power 180nm process having port B, MUL, and DIV implemented, but I'm not sure it would be worth Parallax's while to move in that direction post-P2.
  • pik33pik33 Posts: 2,415
    edited 2012-06-17 08:14
    P1.5 would be simply P2 in 40 pin package, as a direct pin to pin but 10x faster replacement for P1 and easy start point for hobbyists.
    And P3? Maybe 64-bit architecture? Then source and destination PASM instruction fields could have 24 bits - up to 16 M entries in cog ram. And then some GB of hub ram... And 1 GHz clock... all of this with 1W power consumption.
    In 2020 this may be easy...
    edited 2012-06-17 13:52
    pik33 wrote: »
    P2 needs dual power supplies, 3v3 for the I/O and 1v8 for the core. Parallax has already said there won't be a DIP version.
    P2 designs also won't have the battery life of P1, which is one thing that will keep the P1 a viable product for some time.
  • jmgjmg Posts: 15,194
    edited 2012-06-17 16:00
    markaeric wrote: »
    Why should larger be the 'natural assumption' ?
    markaeric wrote: »
    64 P1-esque GPIO
    That is jumping in two directions at once - the present Prop 2 is die-limited in the 128 pin package, so throwing in MORE features on a wish list, is going to make the die even larger.
    There is Room for a Prop 2-Tiny, but to get there, you need to decide what can be trimmed, not added.
    ** 64 P1-esque GPIO
    Less I/O is a natural step, for a P2-Tiny.
    ** one or two 32-bit SERDES per cog with clock generation/capture
    We all hope this (in some form) has made it into the p2 silicon. Cost is very low, and it could even share/overlay Timer-SFR's if needed.
    ** Upgraded video engines - up to 16-bit color VGA/composite
    The P2 DACs should be there already ?
    I'll add one more :
    ** Wide supply support, and on Chip core regulator.
    The latest Microcontroller example of this I've seen supports 5V Vcc / 5V Io, and a 1.5V FLASH core, with 0.9V RAM-keep option
    Now we come to what can be removed, to shrink a die ?
    a) High speed DAC on every pin makes cell duplicate easy, and could make for a great Universal Tester (with wider vcc) but realistically, what high volume designs are going to use more than a handful of all those DACs.
    I'd explore the die savings of limiting the number of pins having the full-suite of Area costly Analog Features.
    b) Pseudo Static (hidden refresh DRAM) is much smaller than SRAM, so is a candidate for Main memory. This is already time-sliced, so even if another slot was added purely for refresh, that is a small overhead to pay for a SHIPLOAD more RAM.
    c) It would be nice to make COGs asymmetric, but I'm unsure of the RAM:Opcode resource splits.
    A problem here, is the COG memory has many port access, (so is large) but if it was under 50% of the total Cog, then it could be practical to Thread/Time slice one Cog's OpCode engine, to give a number of "Virtual Prop1 Cogs"
    Given Prop 2 is x4 x2 the speed of Prop1, you might even manage 1 P2.COG sliced to emulate 8 P1.Cogs. It needs 8x the Memory, so that each virtual prop1 cog, runs in its own memory, just the core-resource is swapped on a deterministic basic.
    Legacy code support becomes very easy.
    What you gain here, is you need FEWER of these Smarter COGs, so hopefully do make a die-gain
    That swap-allocate could even be Soft controlled, allowing a run-time choice of Number, or Speed - using feature d) would allow access to the 'spare' RAM if you chose speed.
    d) Prop COGs are powerful, but a little insular, and with a hard ceiling.
    I'd look at some means to cross-port a small section of COG memory, with a sibling, to give high bandwidth task splitting.
    In the simplest form, the read/write access of a small piece, would simply swap with a sibling.
    e) To crack the ceiling issue, some means of hardware fast-reload at a function call level, any/all of COG memory.
    Extending on c) those COG planes, could become like a cache, and one could even pre-load to better balance bandwidth.
    Good software support is important for this type of approach, and you can divide-and-conquer this, with a slower SW patch solution,
    before you lock-in the faster hardware.
    edited 2012-06-17 18:30
    jmg wrote: »
    Now we come to what can be removed, to shrink a die ?....
    This is the best idea yet...
    There are many wasted (unused) hub cycles, so refreshing using these unused cycles should be easy. I know of no code that can use all cogs simultaneously and require every hub access slot (8 cycles on the P2). Only a test program would be capable of this.
    A refresh cycle could be made to occur from 80% onwards, waiting for a free slot.
    Another idea would be that the hub be sectioned into 2 halves - a lower X bytes and an upper X bytes (eg 1MB & 1MB). Then the refresh could occur in the half that was not being accessed. Again, not all cogs are going to be accessing the same half.
    I am sure there is a solution here just waiting to be found.
    1) For some time I have advocated for a "Super Cog". It would have banked cog memory. The upper 1KB could be bank switched. I no longer think it needs more hub cycles with the P2. But perhaps with the P2 architecture, overlaying from hub and LMM would be fine instead of requiring banked cog memory. Maybe this is moot on the P2.
    2) Only 4 cogs really need all the extra video logic, though I am hoping that can be used in reverse to clock data in.
    Maybe if the last 2 cogs could be replaced with 4 - 8 simpler cogs with just basic counters (similar to the P1 but without the video and tv logic, but with the added bonus of being able to clock in or out 32 bits, similar to the vga style logic). These cogs would have lower hub access cycles - the 2 accesses would be equally shared between these cogs. I think some extra simpler cogs capable of doing some serial type peripherals (serial, I2C, SPI, etc) would be a bonus.
    I have mentioned this too. A fifo style of access would be fine.
    This can be achieved in the P2 by using one of the extra internal pins. A small piece of code could be loaded into the cog that does a waitpeq on the internal pin (minimise power). By setting this pin from the main cog, the slave cog(s) could determine when to load a new piece of code to execute. Now, by software, the length of code to be loaded can be controlled. In fact, it could just use LMM from hub which would be really fast. Once done, the cog could return to its idle waitpeq loop.
    Power: All the newer chips have found a way to minimise power usage. I am not sure how they are achieving this, but it needs to be investigated for the P3 (or P2 variant). Certainly the new vertical (3D) transistors Intel is pioneering is a big breakthrough.
    Anyway, lets just get our hands on the P2 first. Once we can see what it can do we will have a better idea of what can be achieved.
    edited 2012-06-17 19:03
    Cluso99 wrote: »
    Once you add more RAM, I think it is best to do that in COG sized amounts, and then the bank-switch you mention becomes a speed question.
    It is a small (?) step to switch at high speed, and so time-slice all the more complex Opcode logic, to create two (or more) sub-speed COGS.
    That slice % would be under user control.
    edited 2012-06-17 20:40
    I wonder if DRAM could be used for the cogs? I would suggest that it could and there would be no need refresh as long as the waitxxx instructions could cause a refresh when required. From my understanding, refresh can be attained when a write occurs to any location within the block. Remember, each prop instruction actually writes back - only some instructiond do not do this (by "nr"). Then again, perhaps the quad access prevents this???
    edited 2012-06-17 21:30
    I'd like a nineth super cog. Except it would not be a cog it would be an ARM core. It would have access to gigabytes of external RAM via a normal memory bus. It would run linux and host the tools for Prop development. A kind of Raspery PI chip with COGS instead of the GPU hardware.
    edited 2012-06-17 21:50
    Heater. wrote: »
    This forum would be tied up for years trying to agree on what peripherals to add to the ARM core. Better to just add a Pi to the mix - if you can get one - the queue seems to be getting longer, not shorter :(
    edited 2012-06-17 22:04
    Easy solution to that. Just get rid of all the normal ARM peripherals!
    Just have the ARM core, no serial, no SPI etc, etc. Just have lots of cogs in one or more Prop cores.
    All peripherals would then be soft. That is the Prop philosopy after all.
    I'm sort of glad to see the raspi queue getting longer even if it means I have to wait. That means that eventually there will be a huge number of users with same hardware base and the same Linux platform. All sharing their experinces and solving all those niggly problems that will crop up. Not to mention inspiring the growth of hardware gizmos to add to it along with the software to drive them. Bit like a grown up Arduino eco system.
  • TubularTubular Posts: 4,745
    edited 2012-06-17 22:29
    Here at post #12, I'd just like to register my concern about how long this thread might become...
    edited 2012-06-17 22:44
    @Tubular.....At least 1 post longer.
    How about increasing cog ram and using a 32 bit register to provide indirect addressing as 16 bit source and destination addresses.
  • SRLMSRLM Posts: 5,045
    edited 2012-06-17 22:46
    Tubular wrote: »
    Why? I'd be worried if there weren't long discussions here on the forums. That means nobody cares.
    edited 2012-06-17 23:30
    Cluso99 wrote: »
    Probably with little gain, as the Opcode memory is Multi port, plus it needs to be fast, as it sets opcode timing....
    so not an ideal match for DRAM (unlike main memory).
    edited 2012-06-18 00:11
    SRLM wrote: »
    Discussions are indeed healthy, and there is no doubt we all care passionately about our Propellers around here. I'm just registering my observation that all the necessary elements are present for a very long thread (open ended question, Prop2 dreaming, and it's been a while since we forumistas have vented)...
    Anyway better join in I suppose. What I like about the approach to Prop 2 design is the ability to throw computing time to make a faster chip. Just give it to the ex-cray guys and gals and keep crunching for faster results. That's really neat. Who's to say they couldn't keep crunching away using idle time and have a chip 30-50% faster a year or two down the track, with minimal additional design effort?
    I think Chip mentioned a couple of things that may not be added to Prop2 that we might be expecting. I take that (kind of compromise) as a good sign that we are getting closer to real product. But perhaps Prop 3 can look at adding those features back in again
    edited 2012-06-18 00:46
    I must agree that it is a good sign when the threads are lively.
    How long will it take us to find out all the things we could do with a P2??? We have not even found all the neat things we can do with the P1 yet.
    edited 2012-06-18 01:06
    Cluso99 wrote: »
    How long will it take us to find out all the things we could do with a P2???.
    - a DOS box emulation with Gravis Ultrasound
    - Amiga and Atari ST emulation
    - USB and Ethernet ports
    - mp3/flac/ape/ogg decompressing
    - ATA HD interface
    - GEM/KDE/Win like GUI OS
    - fpc/Lazarus
    - first since Atari ST MIDI system without delays
    - wavetable synth
    edited 2012-06-18 01:20
    Let's get rid of the hub memory. It's small and slow but takes up a lot of silicon.
    Instead let's add as much dynamic RAM to each cog as possible. Dynamic is much smaller and with a dynamic ram area per cog we don't need all that quad porting hardware either.
    Ah, you say, cog instructions only have 9 bit address fields and that sets the cog ram size limit.
    Well not really. With out the # cog memory access works through another register with a 32 bit range and so 4G longs of data can be accessed easily.
    Ah, you say, code execution won't work, jmps and such need those 9 bit addresses unless we use another long for each jump address which is wastefull.
    No problem. Perhaps restrict code execution to 512 longs as usual and use an lmm style to fetch code to execute from outside that range. Fetching will be faster than lmm from hub as there is no hub waiting, with an auto incrementing register to use as the program counter things start to fly. Or better yet have that lmm loop done in hardware.
    Allow for cogs to access external RAM via a proper hardware bus. Probably only one cog would be granted this power.
    Ah, you say, without hub ram cogs cannot communicate.
    OK, have a small, 1K, hub for that or put in some cog to cog comms hardware.
    edited 2012-06-18 01:25
    Quad port cog ram is required to attain 1 cycle instructions.
    edited 2012-06-18 01:47
    OK, let's have quad port for the original 512 longs cog ram and single port access for the othe 4GB.
    edited 2012-06-18 03:30
    How about a p3 that looks a lot like the p1 but has io pins like p2 and more ram but has low power consumption and 40 or even 28 pins.
    edited 2012-06-18 05:23
    - Hardware memory caches
    - Larger cog memory
    - More efficient and flexible hub access mode
    - 1080p60 display capability with external DRAM
  • markaericmarkaeric Posts: 282
    edited 2012-06-18 05:28
    Glad to see a lively discussion. I have to admit, I had a feeling I was going to be ostracized for this one.
    @localroger
    I do vaguely recall Chip or Beau mentioning that the P1 wouldn't scale to a smaller process, though I imagine that his AHDL code (or whatever he used) could be used for the automated layout like they're doing with the P2. I also recall Chip asking the guys that run the layout tools to amuse him and tell him what the P2 on a 45 nm process would run at. Obviously, 1GHz is amazing, but that puts it in a whole other ballgame where it's more along the lines of an application processor than a microcontroller. Besides probably locking out hobbyists and even some developers, I couldn't see how well it's architecture would stack up against it's new competition.
    RE: pin reduced P2.. Could definitely be interesting. Let's say a 64 IO device, which is a reduction of 28 pins. I believe Beau said there's about 6000 transistors per pin, which would translate to more than 5.2k of hub memory assuming 4 transistors per bit (I say more because there's also all the die space used for routing). It may not sound like much, but I'm sure many of us would be happy with and additional 5k of hub memory on the P1.
    localroger wrote: »
    Probably not, but Chip did mention that at least the core logic was more efficient than the P1 because he was utilizing some sort of gating.
    Because that's the American way! :)
    I didn't say anything about adding features to the P2, but rather to the P1, which if manufactured on the same process would probably have a MUCH smaller die size. So adding maybe some of the features from the P2 (like one shared math engine, and cog-based SERDES) shouldn't add too much. So if the process and available die size was the same, aside from the little bit of real estate taken up by a few extra features, the rest could go into hub memory, which I would guess would be substantial amount.
    I think DRAM is a scary proposition (no pun intended) for a microcontroller that should generally be energy efficient. Then again, the massive gains in RAM would be fantastic. I suppose hub memory could be split into two chunks - one chunk static, and the other dynamic, with the the dynamic portion having the option to be disabled.
    Time slicing with shadow cog ram would only work if you didn't need all the counters/video generators/etc. that are shoved in each cog. Having to replicate those as well would unlikely result it any substantial savings.
    I had previously been a fan of the super-cog idea, but I just don't see any practical way to accomplish this without there being some significant kludge. Banked memory? Ugh! Different architecture with it's own unique opcodes? Ugh! I don't see any winning.
    Question: How much cog ram do would make us happy? I know, 75847584TB. lol.. It's been mentioned before that the easiest way would be to increase the LONGS to a non-standard 33 or 34-bits. The 4-port cog ram would severely cut down on hub space, but I guess it could be partially made up using dram.
    I have always advocated the inter-cog comm port. I would prefer it to be more than 32-bits wide though, so can have async communications between cogs with at least one of the channels being 32-bits wide.
    I wish someone would make a vanilla ARM chip (Preferably the Cortex A5) with nothing but external memory and DMA interface. I guess there's really no substantial need for that in the market. Some of the ARM9 parts do come close, but I doubt they would perform substantially better than a P2 utilizing LMM.
    heater wrote:
    Let's get rid of the hub memory. It's small and slow but takes up a lot of silicon..
    Hey now! I like hub ram! :)
    If we have too much cog ram and under utilize it, then it's an even bigger "waste" than hub ram. Ideally, we would have memory that's 8x the core clock so all our problems disappear! Of course, that's not going to happen.
    edited 2012-06-18 05:37
    markaeric,
    How so? No matter how fast the HUB RAM is we have 8 cogs accessing it. They have to wait for each other.
    edited 2012-06-18 06:04
    Heater. wrote: »
    markaeric,
    P2 hub access can be quad longs which really means equivalent to 1 in 2 cycles and IIRC, the indirection registers can autoincrement. So I don't particularly see a big need for more cog ram because it is more beneficial in hub where it can be shared.
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-06-18 13:27
    I'd like to see P1 re-done with the tools/resources that were used to make P2. Maybe call it P8x32B. At the same process, it's possible it may wind up being a smaller, lower-power processor with the same performance. May scale up faster, too. And if there were room to easily add a bit more ram, that would be nice. Keep to the large process, though, and keep the same 6-stage, 4-step-interleave pipeline to keep it compatible with older code.
    My next choice after that would be a P4x32A, with 32 I/O pins, and another 32 I/O pins to make it look like an SRAM so it could be connected to a larger CPU as a peripheral. I imagine the external CPU taking every other slot on the hub. In a lot of ways, the Propeller makes CPLD-like functions accessible to programmers.
    Xilinx has FPGAs with Cortex-A9's in the middle, and even Microchip has some (minimal) programmable logic now (Google PIC CLC).
    edited 2012-06-18 13:54
    I'd like to see P1 re-done with the tools/resources that were used to make P2.... Keep to the large process, though, and keep the same 6-stage, 4-step-interleave pipeline to keep it compatible with older code.
    ?? This is pulling in three different direction at once.
    If you keep the same large process, and same timing, you have gone nowhere ?
    Also, the P2 tools and IP, and months of tuning, is all based on a NEW process and 1 CLK core, so that has to be the 'point of commonality'.
    You can easily allow for optional slow-down timing 'compatible' modes - that's very common now in core upgrades.
    Something like 'Take a P2 and keep throwing stuff overboard, until it fits in a P1 package, and see what results? path could yield a P1.5 ?
    edited 2012-06-18 14:06
    markaeric wrote: »
    The 1.2V core gives you Energy efficiency, and an 80MHz Prop1 is drawing significant power.
    If you meant Static Sleep modes, then yes, DRAM is not as good as SRAM (but could be as good as any WAITxx in Prop1)
    With 90+ pins supporting DACs, and a 128 pin part optimized for speed, it is not clear what the P2 static Icc could be anyway, and the general trend these days is to not ask too much of one chip.
    If you really need deep sleep, add a tiny micro that does that properly, and re-start the big-iron as needed.
    markaeric wrote: »
    A 32 bit counter register is tiny, and the Adder can be Mux'd - the real cost in video generation, is at the pins.
    edited 2012-06-18 14:15
    jmg wrote: »
    I don't remember where, but I thought Chip (or Beau?) said that the P1 would have been lower-power if it had been built with the same tools that were used to build P2. The reasons to keep the same pipeline are for such tricks as the coroutine idea in AN014 and other self-modifying-code situations. The P2 is a bit less consistent in timing than P1 is, so P1 is easier to wrap your head around than P2 is.
    If the final chip could clock up higher because of this change, that would be nice, but I wouldn't count that as a design goal. Reimplement P1 with P2 design process, work on gating/process to get power draw (static and dynamic) as low as possible, then see how high that'll clock.
    edited 2012-06-18 16:35
    P1 Derivatives...
    There are a few concepts that have been learnt from P2 that could likely be ported back to a P1 derivative.
    1) Hub cycle reduction from 1 in 16 to 1 in 8.
    2) Perhaps a small speed improvement by fixing/changing the constraints that are limiting the overclocking. We are achieving ~110MHz in reality, but the PLL or internal clocking seems to be one of the limiting issues.
    3) Implement the B port in a 84 PLCC for 64 I/Os. This requires consideration of how to access the second 32 I/O as using the C flag may break existing code. Perhaps an instruction to flip between them (for each cog) somewhat similar to P2. Presuming the die fits, make a 40 DIP which could use the B port for internal comms (like the additional internal port on the P2).
    4) Add a few gates to give the VGA circuit the additional ability to input the bits from a pin(s) (i.e. deserialiser)
    5) Add more hub RAM & delete most ROM - minimum of 62KB+2KB ROM (similar concept to P2) and boot from SPI (Flash or SD card).
    6) Add another 32bit CNT register for overflow from the first CNT register, and an instruction to access it.
