Help using the MCP23008 — Parallax Forums
Dr_AculaDr_Acula Posts: 5,484
edited 2012-06-20 11:00 in Propeller 1
I would be most grateful for the forum's collective wisdom using the MCP23008 I/O expander on the I2C bus.
ADDIT - solved post #5
A search on the forum gives this thread http://forums.parallax.com/showthread.php?135052-mcp23008-Sourcing-Voltage
Which finishes with
Well, apologies.. I was being totaly and utterly stupid.. I downloaded the i2c stuff from the object exchange and was using the MCP23016 Lib, which of course has different register addresses.... I was not setting a pin high, i was changing it to an input... how stupid of me!
Maybe to make up for my stupidity I should write a driver specificly for this IC
I was wondering if this author would be able to share the code, or if anyone else has written a driver?
There is a very nice MCP23016 driver in the obex here http://obex.parallax.com/objects/251/
And of course the datasheets http://ww1.microchip.com/downloads/en/DeviceDoc/21919e.pdf for the MCP23008 and http://ww1.microchip.com/downloads/en/DeviceDoc/20090C.pdf for the MCP23016
Please forgive my ignorance though, but my eyes tend to glaze over reading those microchip datasheets :( Exactly where are the differences highlighted between a MCP23008 and a MCP23016? Anyway... I find reading code tends to be far more useful. I found some C driver code http://rdpartyrobotcdr.sourceforge.net/documentation/_m_c_p23008-driver_8h.html and source code http://rdpartyrobotcdr.sourceforge.net/documentation/_m_c_p23008-driver_8h_source.html
So the Spin code for a MCP23016 is this
PRI MCP23016_Demo | counter, mcpstate, ackbit
    ' demo the MCP32016 i2c I/O Expander
    debug.str(string("Init...."))
    MCP23016Object.WriteIOregister0(i2cSCL,mcp23016addr,%0000_0000)
    MCP23016Object.WriteIOregister1(i2cSCL,mcp23016addr,%0000_0000)
    waitcnt(clkfreq*2 + cnt)
    repeat counter from 0 to 8
        debug.str(string("Counting..."))
        debug.dec(counter)
        MCP23016Object.writeGP0(i2cSCL,mcp23016addr,counter)
        MCP23016Object.writeGP1(i2cSCL,mcp23016addr,8-counter)
        ' read GP0 state
        mcpState := MCP23016Object.ReadGP0(i2cSCL,mcp23016addr)
        debug.str(string("    GP0 State:  %"))
        debug.bin(mcpState,8)
        ' read GP1 state
        mcpState := MCP23016Object.ReadGP1(i2cSCL,mcp23016addr)
        debug.str(string("    GP1 State:  %"))
        debug.putc("%")
        waitcnt(clkfreq*2+cnt)
        debug.dec(counter)
        case counter // 3
            0 : ' case 0
                debug.strln(string("set GP0 High, GP1 Low"))
                MCP23016Object.WriteGP0(i2cSCL,mcp23016addr,%1111_1111)
                MCP23016Object.WriteGP1(i2cSCL,mcp23016addr,%0000_0000)
            1: ' case 1
                debug.strln(string("set GP0 Low, GP1 High"))
                MCP23016Object.WriteGP0(i2cSCL,mcp23016addr,%0000_0000)
                MCP23016Object.WriteGP1(i2cSCL,mcp23016addr,%1111_1111)
            2: ' case 2
                debug.strln(string("set GP0 Low, GP1 Low"))
        ' read GP0 and GP1 state
        debug.str(string("GP0 State:  %"))
        debug.putc(13)
And to make things really simple, I don't even want to read pins, only write to pins. So all I really need is
1) Initialise the chip - default hardware address A0-A2 all low, which I think from the C code is #define MCP_I2C_ADDR 0x40 /*!< Default base address (A0-A2 tied to gnd) */
2) Send out a byte to the 8 pins.
3) Send another byte etc
Schematic is very simple - MCP23008 on the same I2C bus as the propeller eeprom.
It is a nice little chip - $1.20 from futurlec.
Any help would be most appreciated :)
  • LeonLeon Posts: 7,620
    edited 2012-06-17 04:54
    The MCP23008 is an 8-bit device, whereas the MCP23016 is 16-bit. The MCP23016 is obsolete, and the MCP23017 or MCP23018 should be used instead.
  • JonnyMacJonnyMac Posts: 9,836
    edited 2012-06-17 08:29
    The MCP23017 is very easy to use and doesn't require an external RC circuit. I've attached my [very simple] object. It handles essential configuration and IO.
    edited 2012-06-17 15:56
    Thanks JonnyMac & Leon. I guess what I am looking for is the difference between drivers for the MCP23008 and other chips. Maybe no-one has written a MCP23008 driver yet? If there are no drivers I'll need to write one.
    addit - note to myself http://www.nutsvolts.com/index.php?/blog/post/adding_more_digital_i_o_to_your_16_bit_microcontroller_experiments_part_2_t
    this is the SPI version but it should be the same as SPI.
    edited 2012-06-20 04:50
    Got some code working for the MCP23008. This is a very stripped down version of existing i2c objects and a modification of the MCP23016 driver. Only need outputs at the moment.
    '' Simple I2C MCP23008 demonstration J Moxham
    ''  output to pins (see MCP23016 objects in the Obex for input and other commmands)
    '' Thanks to James Burrows and Michael Green
    '' based on C code http://www.nutsvolts.com/index.php?/blog/post/adding_more_digital_i_o_to_your_16_bit_microcontroller_experiments_part_2_t
    CON
      _clkmode      = xtal1 + pll16x
      _xinfreq      = 5_000_000
      SCL = 28          ' pins never change
      SDA = 29
    PUB i2c_Demo
        i2c_Initialize                                      ' start the driver
        i2c_writelocation($40,$0,$0)                        ' write to device $40 MCP23008, all pins are outputs
        repeat
          i2c_writelocation($40,$09,%11111110)  ' device $40, address $09 is output - leds are active low
          waitcnt((clkfreq/2)+cnt)              ' small delay
          i2c_writelocation($40,$09,%11111101)  ' next led on
          i2c_writelocation($40,$09,%11111011)
          i2c_writelocation($40,$09,%11110111)
          i2c_writelocation($40,$09,%11101111)
          i2c_writelocation($40,$09,%11011111)
          i2c_writelocation($40,$09,%10111111)
          i2c_writelocation($40,$09,%01111111)
    PUB i2c_Initialize               ' An I2C device may be left in an
       outa[SCL] := 1                       '   reinitialized.  Drive SCL high.
       dira[SCL] := 1
       dira[SDA] := 0                       ' Set SDA as input
       repeat 9
          outa[SCL] := 0                    ' Put out up to 9 clock pulses
          outa[SCL] := 1
          if ina[SDA]                      ' Repeat if SDA not driven high
             quit                          '  by the EEPROM
    PUB i2c_Start                   ' SDA goes HIGH to LOW with SCL HIGH
       outa[SCL]~~                         ' Initially drive SCL HIGH
       dira[SCL]~~
       outa[SDA]~~                         ' Initially drive SDA HIGH
       dira[SDA]~~
       outa[SDA]~                          ' Now drive SDA LOW
       outa[SCL]~                          ' Leave SCL LOW
    PUB i2c_Stop                   ' SDA goes LOW to HIGH with SCL High
       outa[SCL]~~                         ' Drive SCL HIGH
       outa[SDA]~~                         '  then SDA HIGH
       dira[SCL]~                          ' Now let them float
       dira[SDA]~                          ' If pullups present, they'll stay HIGH
    PUB i2c_Write(data) ': ackbit
    '' Write i2c data.  Data byte is output MSB first, SDA data line is valid
    '' only while the SCL line is HIGH.  Data is always 8 bits (+ ACK/NAK).
    '' SDA is assumed LOW and SCL and SDA are both left in the LOW state.
       'ackbit := 0                         ' ack bit commented out as this chip always works
       data <<= 24
       repeat 8                            ' Output data to SDA
          outa[SDA] := (data <-= 1) & 1
          outa[SCL]~~                      ' Toggle SCL from LOW to HIGH to LOW
          outa[SCL]~
       dira[SDA]~                          ' Set SDA to input for ACK/NAK
       outa[SCL]~~
       'ackbit := ina[SDA]                  ' Sample SDA when SCL is HIGH
       outa[SCL]~
       outa[SDA]~                          ' Leave SDA driven LOW
       dira[SDA]~~
    PUB i2c_writeLocation(device_address, register, value)
      i2c_start                            ' start the chip
      i2c_write(device_address)            ' write to this chip
      i2c_write(register)                  ' write to this register
      i2c_write(value)                     ' write value
      i2c_stop                             ' stop the chip
  • average joeaverage joe Posts: 795
    Very nice work Doc!
    I've decided to use one of these chips on my "foot-controller" since it's due for a rebuild so adding input functions will come soon. These chips seem fairly simple in theory and the code seems to agree. Now to test the theory!
