Prop plug to program 5v Arduino — Parallax Forums
NoodlesNoodles Posts: 19
edited 2012-06-15 18:13 in Propeller 1
Is there a way to program my Arduino with a Prop Plug ?
  • xanaduxanadu Posts: 3,347
    edited 2012-06-14 20:53
    Where there is a will, there is a way. But why? Have you not a USB A-B cable laying around?
    edited 2012-06-15 13:13
    Some of the Arduino boards don't have a built-in USB adapter. In particular it seems that SparkFun sells an Arduino on a breadboard that lacks the USB and you need an external one to program it. I think the question may be referring to that style Arduino.
    IIRC some loaders for other chips use RTS instead of DTR, so you may need to add a wire and pin for this. Alternately, you may need to bypass the transistor reset circuit.
