Just one battery for the Propeller.
LoopyByteloose
You have 10Ah at 3.2V. What more could you want? If you need to jump to 5V for some devices, Polou has tiny boards.
http://www.youtube.com/watch?v=DWMFizC3H7k&feature=related
Yes, looks to be LiFePO4
3.2V gives the game away that its a LiFePO4 - a traction battery cell I suspect. No one makes disposable batteries that big anyway AFAIK.
Take a look at the 'PP-Series' cells...
http://en.wikipedia.org/wiki/List_of_battery_sizes#PP_series
Most of those are uncommon or no longer in use, but some still exist.
My uncle used similar batteries in the electric fences on his farm. Takes a lot of power to deliver 5000V pulses a whole summer... (Add 'training pulses' of 8000V, or the ability to burn off grasses that touches the wire, too, to get a better idea of what is needed)
There are real hazards in confusing the two.
Running these at excessively high voltage may cause a fire
Running these at excessively low voltage may short circuit the battery and cause a fire the next time you try to charge it.
And there is a maximum safe temperature which is a bit higher for LiFePO4.
The nicest thing about LiFePO4 is that it is least toxic of all the Lithium batteries.
For LiFePO4 do NOT use voltage above 3.9V for charging - the LiMO2 can go to a higher 4.25V
For LiFePO4 do NOT use voltage below 2.8V for charging - the LiMO2 may only go to 3.00V
For LiFePO4 do NOT go over 60 degrees centigrade - the LiMO2 may only go to 50 degrees centigrade
And above all else, consider these only guidelines in lieu of other facts provided by the manufacturer. But be aware that a lot of vendors on line are claiming to sell 3.7volt LiFePO4 when that is NOT chemically possible.
I try to get good information only, but I fear that inspired bloggers and rather uninformed sellers are very fuzzy on these details.
Read Wikipeida for Lithium Ion and Lithium Fe PO4 cells before you believe too much from others.
