SD Card Help — Parallax Forums
SD Card Help
John BoardJohn Board Posts: 371
edited 2012-06-12 23:42 in Propeller 1
G'day,
I've been playing around with an SD card recently and I've gotten a bit stuck - Could anyone help me?
COn
  _clkmode = xtal1 + pll8x
  _xinfreq = 10_000_000
OBJ
  sd : "fsrw"
  ser: "FullDuplexSerial"
PUB Main  | mount, r
  Ser.start(31,30,0,9600)
  waitcnt(clkfreq*4+cnt)
  ser.str(string(16, "Mounting...", 13))
  mount := \sd.mount_explicit(0, 1, 2, 3)
  if mount < 0
    ser.str(String("Mounting failed."))
    abort
  ser.str(String("SD was found and mounted.", 13))
  sd.popen(string("test.txt"), "w")
  sd.pputs(string("Testing..."))
  sd.pclose
  sd.unmount
  ser.str(String("Wrote 'Testing...' to test.txt", 13))
  if mount < 0
    abort
  sd.popen(string("test.txt"), "r")
  repeat
    r := sd.pgetc
    if r < 0
      ser.str(string("EOF", 13))
      reboot
     if r > 10
      ser.tx(r)
      ser.tx(13)
  ser.str(string("Closing file and unmounting sd card.", 13))
  sd.pclose
  sd.unmount
And the output is:
[code]
Mounting...
SD was found an
  • John BoardJohn Board Posts: 371
    edited 2012-06-12 23:08
    Hold this thought - But don't reply yet! (except about the "\" thing) - I think I've found the problem (101 typos namely).
    -John
    edited 2012-06-12 23:22
    Found the answer!
    COn
    OBJ
      sd : "fsrw"
      pst: "Parallax Serial Terminal"
      num : "Simple_numbers"
    PUB Main  | mount, r
      pst.start(115_200)
      pst.str(string(16, "Mounting...", 13))
      if mount < 0
        pst.str(String("Mounting failed."))
      pst.str(String("SD was found and mounted.", 13))
      sd.pputs(1024)
      sd.pclose
      pst.str(String("Wrote 'Testing...' to test.txt", 13))
      waitcnt(clkfreq/5+cnt)
      pst.str(String("Opening test.txt", 13))
      pst.str(String("File Opened", 13))
      pst.str(String("Reading...", 13))
      repeat
        r := sd.pgetc
        if r < 0
          reboot
        if r > 10
          pst.char(num.dec(r))
      pst.str(string("Closing file and unmounting sd card.", 13))
      sd.pclose
      sd.unmount
    Although I'm still puzzled with the "\" problem
    -John
    edited 2012-06-12 23:29
    that '\' thing catches aborts.
    like
    try
    catch
    any abort will jump up the stack-chain until it hits a '\'. there you need to handle the error
    Enjoy!
  • JLockeJLocke Posts: 354
    edited 2012-06-12 23:31
    I can tell you how the "\" is defined, but I haven't used it in coding myself. From the Propeller Manual (v1.2), page 208:
    \ Abort trap: appears immediately before a method call that could potentially abort. See ABORT on page 47.
    Probably it would be best to refer you to page 47 of the Propeller Manual (v1.2). There is some nice example code on pages 49-50 demonstrating use of the "\".
  • Tracy AllenTracy Allen Posts: 6,664
    edited 2012-06-12 23:32
    Look up "abort" in the manual for info about the "\" prefix. Deep in fsrw are rare conditions that generate an abort. If you open the fsrw object and look at the mount method, you will see several conditions that can occur and an error number that they return. By including the "\" prefix you are telling the program execution to back all the way out to this top level if the error should happen to occur, even if the call to fsrw had been routed via nested methods that are there to handle normal operation.
    I see you have an abort in the program listing you posted. I'm not quite sure what that will do, because at this level there is nowhere to abort to, already the top. You could just as well use a REPEAT there to hold the program.
    Wow - Thanks for all these replies! It all makes sense now,
    Comming from a computer coding background (Java, Python, etc) the "Try, Catch" analogy was something I could relate to quite easily!
    -John
