IR Illuminator help
OK, So I bought these IR LED's on EBay: http://www.ebay.com/itm/290554033785?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I want to make an IR Illuminator as I have an LPR camera that only works in daylight. I would like to run on 12V DC. Could someone tell me what I would need for resistors using all 100 of the LED's? I would like to use as few resistors as possible so as not to take up a lot of space on the board I am using. Thanks for any help you can provide.
If a battery, white type?
Duane J
No, not really. 10 in series would require 13V to 17V to power them.
I think you want enough voltage across the resistor that small voltage difference don't cause dramatic current changes. So you might want to only use five or six LEDs in series so the current remains relatively stable with small changes in voltages.
This was (maybe still is) a problem with a lot of cheap imported flashlights and illuminators. They would put 20 or more LEDs (more for most illuminators) and over drive them to begin with to get more light out of them. Once one LED failed, others would quickly follow.
You can still arrange them in a square, you'll just want to use seven or less (probably less) LEDs per resistor.
A resistor every 5 LEDs might be easiest. You could have the ground wire running across the center of the square. The 12V line could run across the top and buttom of the square with a resistor between the 12V line and the first LED of the 5 LED strand Or it might be better to switch the 12V to the center with grounds on the top and bottom. Either way, I think a 10 x 10 array broken into stands of 5 LEDs would make your task a bit easier.
Are you going to use perf board to mount them?
Here's a 10x12 array I made.
I'd think it should be possible to mount the LEDs closer together than this by staggering the rows. The board I used here was 8cm by 10cm (3.15x3.94") so I think a 10x10 array should be able to fit within a 3" square.
The LM317 regulates the overall current of the four strings of LEDs to 83 mA, or about 20 mA per string. You will need five such circuit blocks for 100 LEDs.
Is 850nm good for IR illumination? Most of the CCTV ones I've seen emit enough visible red light I would think they were closer to ~750nm. I guess it really depends on the camera. I'd love to see your results with it
Nevermind I looked it up most are 850nm.
Basically these are strait silicon LEDs.
The same material as in Photo Voltaic solar cells.
Duane J
I bought some led panels, that had two parallel groups of 56 leds in series. Out of a total of five, only one, with a weak power supply, survived. It was a very bad design, no current limiting resistors, nothing. Most of the leds failed closed, so naturally the rest got gradually brighter until they all went dark.
Keeping the groups smaller means less to replace if(when) something goes wrong in a group, like when you start increasing the current because you want it brighter...
