16 bit ADC - Stamp Friendly
xanatos
The forum search only likes search terms that are greater than 3 characters, so searching 16 bit ADC was quite futile...
Anyone have a preferred 16 bit ADC they like to use - something along the lines of the ADC0801 ... but 16 bits? The 0801 causes me to have to squeeze the total range too much to get the resolution I want.
Thanks...
Thanks...
What are you trying to sense? An instrumentation amplifier might be a better front end approach to reduce any common mode noise, and then apply an ADC to the output of that after a slight amplification. Either way leads are going to need to be extremely short to minimize noise from entering the system.
If 14 bits are enough there are quite a few choices that are easier to work with.
What does your application require as far as sample rate, input type (single ended or differential), and parallell or serial output?
It's true about awareness of noise sources. Given that, a high resolution converter with differential inputs and its own programmable amplifier (PGA) can be cheaper and more direct than a handful of analog components. Direct to digital.
I use the ADS1115, which has 2 channels differential or 4 channels single ended, a built in reference, PGA gains of 2/3, 1, 2, 4, 8 & 16, and Vdd range from 2.7 to 5.5V. It is not fast (128SPS) but it is meant for instrumentation. On the high gain setting, full scale is 0.256V, the least significant bit is 7.8µV. I use it for digitizing thermocouples directly. Xanatos, are you using 2p series Stamp? This chip has an i2c interface.
The ADC0801, being an 8-bit unit, only gives me 255 steps. When using this with an LM34, if I want temperature resolution to 0.1 degrees (1 millivolt per tenth of a degree), then I have a maximum temperature range of 25.5 degrees. I need a temperature range of (at minimum) 60 to 212 (that's 152 degrees, or with 0.1 degree resolution, 1520 steps.) I've looked at 12 bit ADCs, but they spec out to 1.22mv sensitivity. So if I use a 16 bit ADC, in my logic, anyway, the noise variations would be relatively trivial as long as they allowed me to sample the LM34 output roughly once per second. That noise could vary by up to 500 uV and as long as it was still floating around the 0.1 degree or 1mv zone. If successive readings occasionally bounced between, say, 100.3 degrees and 100.4 degrees because of a slight noise - it doesn't seem to me to be a huge issue, especially because these values will be averaged and plotted over time, and trends are what I am looking for, rather than an instantaneous, exact measurement with sub-microvolt precision. So I figure that while the individual numeric values I get out of a 16 bit ADC may vary quite a bit, when translated to temperature, they'll likely stay well within the .1 degree range I need.
Am I thinking correctly, or am I missing some critical understanding of ADCs?
Or should I be using another measurement style? After all I've read about compensation for thermocouples and the issues raised there, the LM34 seems like a good choice given it's wide available temp range (up to 300 degrees) and ease of use. Thoughts?
Dave
For example, if you used an MCP3202 with a precision voltage reference of 2.56V you would have a sensitivity of 2.56/4096 or 0.625mV per bit(step) or 0.06 degrees F.
The same adc with a 3.3V reference would have a sensitivity of 3.3/4096 or 0.8mV per bit or 0.08 degrees F.
The 1.22mV sensitivity comes from using 5V as the reference.
I agree with Kwinn about the reference. Consider an ADC like the MCP3204 or MCP3208 that Parallax sells. It gives you 12 bits, an SERIN/SEROUT interface, and a reference input. Tie the reference input to 4.096V and viol
Thanks for the info - this IS useful. And apologies, it wasn't the ADC0801 I was using - it was the ADC0831, which uses only 3 pins (CS, Ck, DO). Years ago I used a ton of ADC0804LCN chips for stuff, and there's a groove worn in my brain for that number when referencing ADCs! :-)
The MCP3204, MCP3208 and ADS1115 all look very good at this point, I'm downloading datasheets on them all at the moment.
I've ordered the MCP3204 chips - they'll be perfect! (In combination with the MCP1541 precision 4.096V regulators I ordered as well)
Thanks for the help everybody!
Dave
Thanks again for all your help!
Dave
