Updated rctime and temperature info
Hello, I am very new and I sure this is a very old question, but I would like the most up to date info. I would like to use the RCTIME to measure temperature. Assuming that the prefered way of wiring is used, what thermistor and capacitor did you use? I may measure the temperature from a distance of 10ft. I am also assumming calibrating reading to actual temperature is a must. Thank you...
BTW, there are more modern one-wire and I2C sensors that can output digital temperature directly, but those are trickier to use:
http://www.ebay.com/itm/Dallas-DS18B20-DS1820-Digital-Output-Temperature-Sensor-/120928023718?pt=LH_DefaultDomain_0&hash=item1c27df34a6
Here's a premade thermometer with a 10-foot cable: http://www.ebay.com/itm/Indoor-outdoor-thermometer-Taylor-Digital-Temp-with-Alarm-Clock-Model-1408-/330743907415?pt=LH_DefaultDomain_0&hash=item4d01df8457
But DIY rules. Nothing wrong with using a thermistor, and RCtime, it's a great learning experience and a rite of passage IMHO. A thermistor can be quite accurate when calibrated properly.
Try this link. It is for the stamp 1. However, the math and tricks apply to the stamp 2. You can even use MS Exel. to write the equation. Or create the equation from the thermister data sheet.
SJW
SJW
