Position coordinates not updated, PMB-688 gps module and arduino issue
Hi
I bought a PMB-688 GPS receiver and an Arduino Uno. I need to get gps location coordinates to serial monitor. I connected yellow gps cable to digital pin 6, red cable to 5v, black to ground.
After a couple of seconds, the Gps led stops blinking and stays solid.
I used tinyGPS and SoftwareSerial library. Following is the code I used:
When powered on, arduino serial monitor lists latitude and longitude coordinates, but they're always the same, even when I move gps module.
Does anybody knows why this could happens? Suggestions are appreciated!
Indeed, I checked the raw strings received without tinyGPS library, and it turned out that some GPRMC messages overlaps with GPGGA messages such as:
$GPRMC,143044.000$GPGGA,143045.000,4152.9430,N,01119.2805,E,2,10,0.8,50.0,M,46.8,M,1.8,0000*45
Thanks for your help!
#include <SoftwareSerial.h>
#include "TinyGPS.h" // Special version for 1.0
TinyGPS gps;
SoftwareSerial nss(6, 255); // Yellow wire to pin 6
void setup() {
Serial.begin(9600);
nss.begin(4800);
Serial.println("Reading GPS");
void loop() {
bool newdata = false;
unsigned long start = millis();
while (millis() - start < 5000) { // Update every 5 seconds
if (feedgps())
newdata = true;
if (newdata) {
gpsdump(gps);
// Get and process GPS data
void gpsdump(TinyGPS &gps) {
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
Serial.print(flat, 6); Serial.print(", ");
Serial.println(flon, 6);
// Feed data as it becomes available
bool feedgps() {
while (nss.available()) {
if (gps.encode(nss.read()))
return true;
return false;
