Servo Center 3.1 and BS2
I have a Servo Center 3.1 Serial Interface 32 Servo Controller board. I am trying to figure out if there is any way that I can implement this in to a BS2 chip on a BoeBot Board. I am pretty sure there is a way to code it in VB 10 but I was hoping that there may be someone ot there that is smart enough to figure out a way to connect it directly to the BoeBot board and program it using the PBasic. Here is a link to the schematic for the SC 3.1 http://tech.yostengineering.com/servoFolder/servoFolder/servocenterUSB/ServoCenter31Schematic.pdf
If you can communicate with the controller, you'd just send it commands. The protocol is available here.
One other question that just came to mind. Would I need to connect a ground from the ServoCenter board to the BoeBot board? I know it may seem odd, but I have found in the past with Stepper Drivers that I have to do this.
