Problem with Propeller BOE ADC
Hi, Folks,
I just received my first Propeller BOE and was trying out the new onboard ADC function. I downloaded the spin code folder for Section 5 - Measure Voltage from http://learn.parallax.com/node/103 and ran "Simple ADC Test.spin", which measures the voltage on the wiper of a pot hooked across 5V and displays the ADC count on the PST. The code returns "-1" instead of the expected ADC count. I checked the wiper voltage of the pot with a DVM, and it's there. The default input channel was 0 for the code. I changed the code to monitor channels 1 and 2, all with the same result. All support objects are in the same folder. The -1 is returned by the "In" method of "PropBOE ADC.spin". The best I can tell, it looks to be generated when expected data is not received from the ADC chip.
Any ideas? The relevant code is posted below. The complete code archive is attached.
Thanks in advance!
....Don
Here is "Simple ADC Test.spin":
Here is In() from "PropBOE ADC.spin":
Thanks in advance!
....Don
[FONT=Times New Roman]OBJ
system : "Propeller Board of Education" ' PropBOE configuration tools
pst : "Parallax Serial Terminal Plus" ' Terminal communication tools
adc : "PropBOE ADC" ' A/D Converter on PropBOE
time : "Timing" ' Timing convenience methods
VAR
long ad ' Stores A/D conversion Result
PUB Go ' Program starts here
system.Clock(80_000_000) ' Propeller system clock -> 80 MHz
repeat ' Main loop
ad := adc.In(0) ' Get AD0 analog to digitla conversion
Display ' Call Display method (below)
time.Pause(50) ' Delay for 50 ms
PUB Display
''Display Method
''Sends cursor home, then displays ad=value and clears
''to right of value.
pst.Home ' Home position on screen
pst.Str(String("ad=")) ' Display AD=
pst.Dec(ad) ' Display analog/digital measurement
pst.ClearEnd ' Clear to the right of the value
[/FONT]
[FONT=Times New Roman]PUB In(channel) : adcval | pointer, acks, chan
{{Measure input voltage at one of the Propeller Board
of Education's analog inputs: A0, A1, A2 are sockets
below the breadboard, and A3 is connected to an
amplified microphone output.
Parameter: channel use 0, 1, 2, or 3 for A0, A1, A2,
or A3}}
ifnot configured
i2c.Init(29, 28, 0_0011)
ifnot cog
pointer := |< (channel + 4)
acks := i2c.poll(0)
acks += i2c.ByteOut(pointer)
acks += i2c.poll(1)
adcval := i2c.ByteIn(0)
chan := adcval>>4
adcval &= 11
adcval <<= 8
adcval += i2c.ByteIn(1)
adcval >>= 2
if acks <> 0 or chan <> channel
adcval := -1
else
repeat until not lockset(lockID)
adcVal := adc[channel]
lockclr(lockID)[/FONT]
I went to the datasheet for the onboard AD7993 ADC chip and noticed that there were two versions of the chip, 7993-0 and 7993-1. Each version had its own I2C address (for the AS pin tied to VSS, the way the BOE is wired).‘
'Just for the heck of it, I replaced the default %010_0011 address (which is for version 7993-1) in PropBOE ADC.spin with the version 7993-0 address (%010_0001) and everything started working!
Tech support has been notified and will be passing this info on to the PTB's.
...Don
