PING))) sensor trouble
I recently purchased a ping))) sensor for my boe bot kit. I wired everything up and used the sample program and wiring diagram found here http://www.parallax.com/Portals/0/Downloads/docs/prod/acc/28015-PING-v1.6.pdf. However when I went to test the sensor using the sample program called PingMeasureCmAndIn.bs2 the sensor would only return the same value regardless of how far or how near an object was. I even tried wiring the sensor up to an arduino uno board and the problem persisted. Any suggestions or aid would be greatly appreciated
