Interesting ethernet/wifi module — Parallax Forums
mojorizingmojorizing Posts: 249
edited 2012-08-13 22:09 in General Discussion
Curious if anybody has used the ez web lynx module from http://ezweblynx.com/ ?
    edited 2012-06-03 17:57
    No - haven't tried it. But looks very interesting.
    Programming a propeller via some sort of cheap wifi module must be where things are heading.
    edited 2012-06-04 06:43
    Recently I was digging out my IRda dongle for a project and I have a Bluetooth dongle as well. By dongle, I mean that these are USB interface.
    In any event, I came across a comment that the Bluetooth actually interferes with Wifi as they share the same frequencies. So it may be best to just go to an all Wifi senario.
    Frankly I am more interested in the IRda and IR remote as transmission cannot go through walls and be easily snooped by unknown persons. Having
    Linux has a very usefuL IR remote project called LIRC which provides excellent software for decoding any remote and setting up remote control of a computer under Linux OS. Most people have created a dedicated music server, but in some cases the music server is also their file server, printer server, and more.
    Having LIRC decode your remote makes coding a Propeller to respond to the remote much easier and faster. I have tried using the sound care and oscilloscope program in the past and it is all rather tedious.
    edited 2012-06-04 07:46
    The Rovingnetwork modules at Sparkfun are less expensive - you might be interested...
    http://www.sparkfun.com/products/10822 (XBEE physical format)
    http://www.sparkfun.com/products/11049 Breakout board
  • MicksterMickster Posts: 2,907
    edited 2012-06-06 01:21
    I'd just like to comment that I have quite a lot going on with BT and WiFi and have had no clashes whatsoever. As it happens, I have two of the more powerful 232/BT (class 1) devices sitting right next to my wireless hub and connected to MCU-based devices that constantly stream data to and from an Android-based tablet and any glitches would be immediately apparent. On the WiFi side, I have Skype video chat + gotomypc open between my two offices for at least eight hours/day and it is rock-solid. This particular PC is less than 10' from the class-1 devices and also has its own class-2 device plugged in to a USB port and streaming data without glitches.
    Just my $0.02
    Mickster
    edited 2012-06-06 03:33
    Thanks. I have a Bluetooth dongle and a Palm Zire72 PDA that has Bluetooth. But because of the early claims that Bluetooth was easy to snoop, I've never really used it. I was thinking of getting it going, but then I saw that comment and wondered if I should.
    I am really gung ho for IR for security. I don't even have my Wifi on the same ISP as my home computer.
    But the more I think about it, I would probably NOT be using my Wifi and Bluetooth at the same time - so conflicts might be minimal. I suspect in a Starbucks - where you have 15 wifi users and people walking around with BT in the cell phones, there might be a lot of interference.
  • riya78992riya78992 Posts: 2
    Recently Whiznets has also Announced Preloaded Embedded Wi-Fi Access Point Modules.
    You can check here:
    http://www.prweb.com/releases/WiFiSoftAPMode/WhiznetsEmbeddedM2M/prweb9574873.htm
