Working with logic functions and negative numbers
I´m working with Parallax MMA7455 3-Axis Accelerometer Module and a BS2P module calculating positioning.
During acceleration processing I need to know it a value is inside a "window" (this is actually a mechanical noise filter).
The logic is quite simple and uses "AND" logic. If an acceleration value is less or iqual than an upper value "AND" greater or equal than a lower value then the acceleration is "inside the window".
This logic should work for positive and for negative values.
However it works only for positive values. For negative values I had to change "AND" for "OR", which is not logically correct but produces the desired values.
Has anyone faced this issue?
I attached a software that demonstrates this behaviour.
If all number as negative ones, "AND" works fine. The problem appears when there are negative and positves numbers.
I noticed that PBASIC has difficult to work with negative numbers.
Even a simple test IF -3 < 0 does not work
Again this test works if both number are negative or positive. If on of them is negative, than this test doesn't work
The best way to figure out if a number is negative is by testing bit15.
Thanks for your answer.
' {$STAMP BS2p}
' {$PBASIC 2.5}
test VAR Word
test=-3
IF test < 0 THEN
DEBUG "test less than 0",CR
ELSE
DEBUG "test greater or equal to 0",CR
ENDIF
DEBUG CR
IF test.BIT15 THEN
ELSE
ENDIF
STOP
