Possible power supplies for Homework board?
I have decided to built my project using a homework board. I'm using it for the stamp and the usb basically since all other circuitry will be on another board. What would the upper and lower limit of acceptable power to the homework board be? It has 9V battery clip only but I'll be supplying regulated dc. I have 12V and 6V available already to power other parts of my circuit and wasn't sure if the 5V regulator on the board would work if I supplied the 6VDC or if I need another 9V regulator?
The MC7806 I'm using to provide power for the servo specs Vout+2V as min. input voltage but it doesn't seem necessary with this one? Think I'll try the 6V and see what happens.
I couldn't find specs on Parallax site either. Never even dawned on me to read the chip - sorry.
If you power the Stamp from +12V, its on-board regulator will be required to drop 7 volts...which in turn causes it to become rather warm (ask me how I know). It'll work, but that Vreg gets hot. Best to power it with a lower voltage.
