Chapter 9 Acitivity 1 Version 2.2
I having problems with the transistor in this section. Was there ever any issue with the layout for this or (assuming I haven't messed up the wiring - which I've redone 3 times) do I just have a bad transistor?
Can I test this like a relay? I attempted testing it earlier, but wasn't sure if I was doing it correctly.
EC
EC
"Chapter 9 Acitivity 1 Version 2.2" of what? (A link would be nice.)
What kind of transistor are you using.
What did you expect to happen? What did happen to make you think something is wrong?
Probably a moot point now since I went out and purchased several bags of transistors since I'd need them later for a robot of some kind.
But can you test them like relays? My multimeter doesn't have a diode or transistor tester.
EC
I just want to make sure you carefully read Mike's description of the LED. The drawing makes it look like the short lead is connected to Vdd; the long lead (on the anode side) connects to Vdd not the short lead.
The flat side of the LED Mike mentioned is sometimes a small "nib" of plastic. Whatever shape it may be, the side with an edge different than the rest of the LED is the cathode side (in this circuit the cathode connects with the transistor).
EC
