1pcs Wireless Bluetooth Transceiver Module RS232 / TTL HC-05 $6.44
Anybody try these yet?
http://www.ebay.com/itm/1pcs-Wireless-Bluetooth-Transceiver-Module-RS232-TTL-HC-05-/251066012059?pt=LH_DefaultDomain_0&hash=item3a74b3519b
Sal tried the slave version with propforth, and after configuration, it took about an hour to to get it going. The only issue was soldering up to the little pads. He's got it running at 230400 and its pretty quick. He can't tell by eye if its slower than wired, but the buffering is different so he can see it scroll differently. We think it should work with any rig as a cable replacement.
Sal is going try the master/slave version, so we can use it as MSC prop to prop communications for the multi-prop Go channels rig. Fromn the looks of it, we should be able to add bluetooth to anything with a serial port.
Any comments or insights?
I don't know how similar the modules are to the one you linked to. I personally haven't tried using Bluetooth with the Prop yet.
