Use ColorPal for an ICC profile
GordonMcComb
I'm looking to create a custom ICC profile for a color printer, using a ColorPal sensor. No problem getting the values from the ColorPal, but I'm having a tough time finding good resources on how to convert the color chip readings to the format expected in the ICC profile. Most of the tools I see are printer specific -- for example, for all-in-one printers you might print out a sample then rescan it back in. While this happens to be an Epson printer, I need the solution to be generic.
Has anyone experimented with something like this? Basically this is a poor man's ColorMunki.
-- Gordon
-- Gordon
http://www.argyllcms.com/
appears to have a good collection of tools for converting optical values from various sensors and creating a standard ICC profile for use with drivers and software. It's a bit convoluted, but at least it's doable.
I realize this is somewhat arcane, but every print shop and professional photographer in the world would be interested in creating their own custom color profiles, if they could -- now they either do it with expensive equipment, send it out to a specialist and pay $35-75 a pop, or just do without and suffer off-coloration. The nearest cheapest solution for reflective colorimetry is about $500. It does use a spectrophotometer, and from what I can tell the ColorPal is a simpler tristimulus colorimeter. But if it works a Prop and ColorPal combo is a whole lot cheaper than five hundred bucks.
(One thing that has to be worked out is any UV brighteners in inks, pigments, or substrate. Without a UV source to add to the mix the colors will be off.)
-- Gordon
I'd think you could still get by with just three colors using reflective colorimetry since a color printer only uses the three sets of dies. Not that I know much about this stuff. I do think it very interesting the way we humans see color. It still amazes me that red and green light mixed in the right combinations looks yellow.
While I don't have color blindness, my wife and I often refer to my shirts as different colors. My brown shirt is green to her (slightly brownish), while I know darn well it brown with slight greenish tint. I've often thought of using a ColorPal to see how the rest of the world defines the colors my wife and I see differently.
