Servos require continual control pulses, about every 20ms. That's why there's a PAUSE 20 after each set of PULSOUTs (except for the last one ... an omission?)
Your program produces a single pulse pair for each character received. That won't do unless there's a continuous stream of such characters. You may also need to adjust the PAUSE time to reflect the time needed to receive each character.
Okay I located the BS2 Program that Parallax wrote and loaded on to my BOE, and I seem to be having the same problems I can get the BoeBot to spin left or spin right but no forward or backward movement. I tried messing around with the PAUSE values and nothing happens.
Like I said above the code works intermittenly then stops working. Example I will press and hold "W" to move forward and it will jerk forward and then nothing, I can sometimes get it to turn in circles but nothing works reliably its all spontaneous. I know that its not my signal form on Xbee to the other they are only a foot apart.
Here is the code:
' File...... xbee_demo.bs2
' Purpose... to demonstrate serial communication through the XBee
' Author.... Parallax, Inc.
' E-mail.... support@parallax.com
' Started... 9-28-2010
' Updated...
' {$STAMP BS2}
' {$PBASIC 2.5}
[ Program Description ]
' This program is meant to drive a BOE-Bot by receiving commands from an
' XBee wireless radio. The commands are simple ascii characters, the
' the charachters 'a, s, d, and w' on the keyboard are used to control
' how the BOE-Bot drives.
[ Revision History ]
[ I/O Definitions ]
XBEE_TX PIN 1 'connect to DIN pin on XBee module
XBEE_RX PIN 0 'connect to DOUT pin on XBee module
L_MOTOR PIN 13
R_MOTOR PIN 12
[ Constants ]
L_FWD CON 825
L_REV CON 685
L_STOP CON 750
R_FWD CON 685
R_REV CON 825
R_STOP CON 750
BAUD_MODE CON 84 '9600 Baud, 8n1 true
[ Variables ]
i VAR Byte
rx_data VAR Byte
[ EEPROM Data ]
[ Initialization ]
Initialization:
LOW L_MOTOR
LOW R_MOTOR
[ Program Code ]
Main:
DO
SERIN XBEE_RX, BAUD_MODE, [rx_data] 'get data from the XBee
SELECT rx_data
CASE $61 ' ascii for 'a'
GOSUB Turn_left
CASE $73 ' ascii for 's'
GOSUB Backup
CASE $64 ' ascii for 'd'
GOSUB Turn_right
CASE $77 ' ascii for 'w'
GOSUB Forward
ENDSELECT
LOOP
END
[ Subroutines ]
Forward: 'drive the BOE-Bot forward
FOR i = 0 TO 10
PULSOUT L_MOTOR, L_FWD
PULSOUT R_MOTOR, R_FWD
PAUSE 20
NEXT
RETURN
Backup: 'drive the BOE-Bot backwards
FOR i = 0 TO 10
PULSOUT L_MOTOR, L_REV
PULSOUT R_MOTOR, R_REV
PAUSE 20
NEXT
RETURN
Turn_left: 'turn the BOE-Bot left
FOR i = 0 TO 10
PULSOUT L_MOTOR, L_STOP
PAUSE 20
NEXT
RETURN
Turn_right: 'turn the BOE-Bot right
FOR i = 0 TO 10
PULSOUT R_MOTOR, R_STOP
PAUSE 20
NEXT
There are all sorts of things that might be wrong with your setup. The servos might not be calibrated. I can't even guess how you'd get turning movements and not forward and backward. That doesn't make sense. As is true with anything like this, throw it out until you've satisfied yourself that the basics work. Download the "Robotics with the BoeBot" tutorial from Parallax's Downloads webpage (under Stamp Tutorials). Work through the calibration procedure as described there. Write simple programs that move first one wheel forward, then backward, then the other. Then get the BotBot to move forward and then backward. Only then should you try this program again. The program should work as is. It certainly has worked for me and for others. It's hard to tell you why it doesn't without detailed information on how it behaves with what inputs. It's not enough to say that one thing or another doesn't work. You need to describe its behavior in detail.
Here is the code:
' Updated...
' {$STAMP BS2}
' {$PBASIC 2.5}
[ I/O Definitions ]
L_MOTOR PIN 13
R_MOTOR PIN 12
[ Constants ]
L_FWD CON 825
L_REV CON 685
L_STOP CON 750
R_FWD CON 685
R_REV CON 825
R_STOP CON 750
[ Variables ]
i VAR Byte
rx_data VAR Byte
[ EEPROM Data ]
[ Initialization ]
Initialization:
LOW L_MOTOR
LOW R_MOTOR
[ Program Code ]
Main:
DO
SELECT rx_data
GOSUB Turn_left
GOSUB Backup
GOSUB Turn_right
GOSUB Forward
ENDSELECT
LOOP
END
[ Subroutines ]
FOR i = 0 TO 10
PAUSE 20
NEXT
RETURN
FOR i = 0 TO 10
PAUSE 20
NEXT
RETURN
FOR i = 0 TO 10
PAUSE 20
NEXT
RETURN
FOR i = 0 TO 10
PAUSE 20
NEXT
RETURN
