GPS Module PMB-648
Hi Everyone!
My name is Metrik and i need help with the parallax GPS Module PMB-648 SiRF. I just got it and was try to use it and cant get it to do any thing and was wanting to know if any one can help. if you need more info just let me know.
Thanks Everyone!
Thanks Everyone!
http://learn.parallax.com/KickStart/28500
Easy to use example code for the BASIC Stamp 2, Propeller, and Arduino.
On your specific problem, it's more useful for you to provide as much information as you can right off, rather than have everyone ask Twenty Questions.
-- Gordon
I'm using an arduino uno, PMB-648 setup just like is shown here: http://learn.parallax.com/kickstart/28500
The gps unit will blink red and then go solid when I assume it gets a gps fix. The arduino is powered and connected via USB to my imac. When I open the serial monitor (Arduinio IDE 1.0) It just populates with garbage:
¼ÿ€þ€þÿþýÿüÿˆûÆåŒû€üVê+þ‹þˆýÿþýÿÿÿÖòþþÿûþ¢üþþûÿüÆúëþýùþÿVëýüÿúÿHîüýÿþþÖúXþÿüüÿÿÿþýÿþÿÖò‹üŒýIÿþÿþþùÿñüþøÿÿü‹þþüûþþVúÿþùþþVúùÿùÿ¢üÖúþùÿúýùþÿÿüÖòIúXî¢üüýÿýÿþýÿÿþþüÿþþ€ü€üXîVúþÿýüÆòüÿþþüÖúŒúVúˆúüøÿÿýÿþÿÿÿÿýÿüŒüVêë€þVê€þ„þ¢þþÿýü€þþÿýÿÿ€þþÿþþþþŒüîüÿÿÿýŒüüþÿÿýIúüþÿþùÿÖúþüùþþþøÿý
Any Ideas?
