MMA7660 sample code?
VonSzarvas
Anyone got the MMA7660 sensor working with the Propeller ?
Looking for some sample code... can be SPIN, PASM, PropBasic!, or even SX/B or some other B-Stamp format. I would be converting to PropBasic, so will publish the code back here when working unless someone has beaten me to it?
Thanks for any help.
hex \ MMA7660 Accelerometer code \ Using Propforth 4.6 : @I2C \ ( device -- ) \ Select device i2cstart i2cwrite drop ; : @ACC \ ( reg -- ) Select Register 98 @I2C i2cwrite drop ; : ACC! \ ( data reg -- ) Write Register @ACC i2cwrite drop i2cstop ; : ACC@ \ ( reg -- dat ) Read Register @ACC 99 @I2C 1 i2cread i2cstop ; : XYZ@ \ ( -- long ) Read first four registers as a long 0 @ACC 99 @I2C 0 i2cread 0 i2cread 0 i2cread 1 i2cread i2cstop 18 lshift swap 10 lshift + swap 8 lshift + + ; : !ACC \ Init the Accelerometer i2cstop 0 7 ACC! 0 5 ACC! 10 6 ACC! 34 8 ACC! e0 9 ACC! 62 8 ACC! 0 A ACC! 41 7 ACC! ; \ List the accelerometer registers : SHOW 0 @ACC 99 @I2C hex 0b 0 do i 0a = i2cread .byte 20 emit loop i2cstop ;Have it solved now.. Very nice to see the readings for shake and orientation working correctly! I will experiment a bit more with making sense of the acceleration data (as I wish to provide a record of movement along a plane, and I think that would also be useful for others), then I will clean up and post the code.
