Please help me write a simple counter code!!!
Tony_tsi
I am fairly new to propeller. I don't have experience with the counter modules built into the propeller. I have read a lot about them but I am struggling to understand exactly how they work. I need to write a code that adds 1 to a value each time a pulse is received on ina[1] and subtracts 1 from the value each time a clock is received on ina[0] I need to do this as fast as possible. I need this to be done in cog 1 but I need to read the value in cog 0. I still struggle to remember how values work when used in different cogs. This code is going to be used to keep up with some optical encoder motors. The output of the motors go through a flip flop circuit so that a pulse is input on line one for each clockwise step and line 0 for each counterclockwise step. This is going to be used on a robot I am building for school.
Thanks for your help.
I've attached a sparsely-commented demo object for you to play with.
You can't both add and subtract with the same counter - but you can use both counters, count the pulses from each pin separately and then take the difference of the phase registers.
Mode 010 does edge detection, set up each counter in that mode with FRQ registers set to 1 and PHS registers set to 0 and the APIN set to 0 for counter A and 1 for counter B. You then read PHSB-PHSA to get the difference.
There will be some discrepancy since you can't read both PHS registers simultaneously though - using PASM will reduce this to 50ns which is probably good enough?
To write the value to another cog you need to pass the address of the variable to be written. In Spin the registers are in HUB ram, with PASM you'll use WRLONG.
So if in PASM something like this:
My programing knowlage includes chapter 1-5 of the propeller education book, as well as some basic stamp experence.
I am trying to spend my summer becoming more familiar with propeller code so that when school starts back I can be a usefull member of the IEEE robot team.
Hey Tony,
Start simple, get the hang of spin and then experiment to see if it will give you the required speeds for your project and make sure the concept does what you think it will. If spin is not fast enough, then move on to PASM. Or learn enough about the counters to use them via spin as a possible state machine to get the speed and spin for the glue logic to make the counters do what you need and interface to the rest of your world. Multiple approaches to doing these, but just experimenting and the prop ed tutorials (no need to buy at Fry's or similar, just download them) will give you the feel for what will work. Rip apart some objects, good ideas there and you can learn some tricks from the masters. Oh, look up PhiPi's traps and tricks document.
The counters are a 7734 of a lot more complex than the APnote leads one to believe, simple circuit on paper, but the versatility designed into the counters is always causing someone to come up with yet another way to do something unexpected with them. 'course, this chip continues to deliver nice surprises........
Frank
http://www.firstspin.tv/2012/03/06/first-spin-episode-015-%e2%80%93-more-directives-and-counters/
We approached it from a newbie's perspective and I think a few people found value in the explanation!
step#1) write a code that uses if statements, operators and values (things I can use well) that adds a count for each pulse on pin 2 and subtracts a count for each pulse on pin 3. Use buttons to simulate simulate signal.
step#2) write a code that tracks the count the same way as step 1 but runs in cog 2 and keeps up with a value that can be displayed on lcd from the cog1.
step#3) write a code that counts up for each pulse on pin 2 using the counter commands.
step#4) write a code that counts up using pin 2 and down using pin 3.
step#5) write a code that runs in cog 2 and tracks the count. use cog 1 to display the count on lcd.
step#6) Hook it up to the motor and see if it is fast enough.
I hope hope by breaking the steps down in this order I can learn it better. I will post as I complete each step!
step#1).spin
I guess your stack is to small...see below
I rarely use COGINIT because I do not care which COG is used.
having a VAR section somewhere defining
to start a COG in SPIN I usally do something like this
COGNEW returns -1 on failure or the ID of the started COG (0-7)
adding 1 gives me 0 for no cog or (ID+1) if started. I save that value in cogID
now I can test
IF cogID
giving TRUE for not 0 aka cog started
to stop it (and test if running)
the second line is tricky but you see that everywhere inPropellerCode POST SET TO 0
COGSTOP wants a ID (0-7) CogID contains (1-8)
so COGSTOP(CogID -1) would do this. But we want to set cogID to also to zero
and cogID~ does that AFTER evaluating. and still returning the correct number
I hope thios helps...
enjoy!
Thank you for the examples. I will be incorporating the cog test in my code this is very helpful. If the cog does not start the robot is lost. lost robot = bad
