I2C and Ds1307 direction bit question
I am practicing with the I2C protocal using the stampworks SW21-Ex33 program with the DS1307 real-time clock.
I was reading the Ds1307 data sheet and it states that the last bit of the address byte is the direction bit (1 for read and 0 for write)
The stamp works program uses the same device ID for both the read and write subroutines using I2COUT and I2CIN. I see how the device ID byte will work for the write mode but do not see the 1 bit that would be required for a read mode. Is this bit handled by the I2Cin and I2COUT commands automaticaly?
Thank you for your help
DigitalC
DigitalC
