Help with MMA7260 Accelerometer
Crack
Hey everyone I only recently got my hands on a propeller demo board after playing around with the arduino for quite awhile.
My problem: I can't find a way to extract the X and Y data from the MMA7260 accelerometer.
The closest I have to come to an example for this is from here: https://sites.google.com/site/parallaxinretailstores/home/memsic-2125-dual-axis-accelerometer however using this with the accelerometer I have does not show values which appear to be correct and the values don't always update when I'm moving the accelerometer.
The Arduino equivalent:
I could then use sensorValue to do whatever I like. Eg. Print to serial terminal.
Any help with this would me much appreciated I have spent hours searching for examples and following spin tutorials.
int sensorValue = analogRead(A7);
I beleive the MMA7260 outputs analog voltages.
Apparently there can be problems with its calibration.
The memsic accelerometer outputs a pulse with a width that is proportional to the force for each of the 2 axis.
What if any adc are you using?
I'll look into ADC when I get back from class.
I saw that article about the calibration problem, thanks for the heads up.
I don't think I was using any ADC so that seems to be my problem.
