Advice
Greetings to All, recently purchased a Wiznet wiz812mj rev 1.0 could not find info to be able to
interface with a BS2. Is SPI also called RS-232? Any references with schematics and example
code will help. Can anyone help, good question.
You won't likely find any specific examples of the use of this with a Stamp, so you'll have to do some research and self-education. Look at examples of the use of SPI with other devices in the StampWorks Manual and the Nuts and Volts Columns archive.
