Nice Relays for $1.10 ea/Prop Potential
http://www.ebay.com/itm/Lot-10-HASCO-713-5-High-Voltage-Reed-Relays-SIP-5V-Coil-2-5A-max-/260991831092?pt=LH_DefaultDomain_0&hash=item3cc4534c34
$11 for 10 SPST reed relays shipped, I bought one lot of 10, and I might get another. Only 2 lots left... Unusually high voltage rating. Unusually low coil current. 500 ohm coil (I measured 518 ohms), so less than 10 mA coil current at 5V operation, easily driven directly by a Stamp or other uC IO pin.
Guaranteed operation down to 3.75V, likely to work at Prop's 3.3 V. I can test at 3.3 V if anyone is interested.
Specs for 713-5 relay at http://www.hascorelays.com/reed_relays_700_series.asp
You better buy 'em before I do.
When dey gone, dey gone!
You can never have too many relays.
Now you're barkin'. And don't miss out on these latching relays on sale for 79 cents. I tested them at 3.1V and they work great. I'm throwin' you gold, Duane! http://www.goldmine-elec-products.com/prodinfo.asp?number=G2011
Will test the reed relays at 3-ishV tonite and report back. You can switch 120V 40W light bulbs with those. Don't dare me.
But I may need significantly more for another project as you mentioned a relay-based CPU...
At 79 cents, a hundred relays are just $79. What would YOU do with 100 latching relays?
You could make a simple electromechanical FPGA.
Good News #2: There are 8 lots of ten left, not one!
Good News #3: All ten of my relays worked at 3.2V (two AA batteries) so 3.3V Properation (I just coined that word, a penny anytime someone else uses it, like Parall-Axe) should be fine!
This relay is a bit marginal running on a 3.3V Prop..
Don't forget, the output FET has a resistance of about 140 ohms, (??), as I recall from a thread a while ago.
So, let say the power supply is 5% low at about 3.1V. And the relay is 500 ohms.
The resultant coil voltage would be about 2.4V. Clearly marginal.
Sure, it may work but will it do it reliably. I'm concerned.
I had a similar problem a number of years ago.
I worked out a circuit that guaranteed my reed relays would switch with a marginal supply voltage.
Here's how it works. Lets start with the pin is low and the relay off.
1. The capacitor charges to a voltage about midway between the guaranteed actuation voltage.
2. The pin goes high which raises the voltage on the relay to about 3.3V + 2.1V = 5.4V and drifts back to 2.1V.
3. The capacitor again charges to 2.1V.
4. The pin goes low and the voltage goes down to 2.1V - 3.3V = -1.2 V and drifts back up to 2.1V.
Note! The resister was chosen to set the "idle" relay current so the voltage is about the average of 3.75V & 0.5V, from the spec. You should do some testing to choose the correct value. Likewise for the non-polarized capacitor.
There are restrictions to the usage. Don't change state until after waiting enough time for the capacitor to charge.
Have fun.
Duane J
You got erco to use a Prop. Amazing!
Kudos to you.
@erco,
I still love the sound of a 'banging" relay.
Duane
So what do you think of the Prop now?
