stop a cog while it's busy? — Parallax Forums
xanaduxanadu Posts: 3,347
edited 2012-05-14 16:43 in Propeller 1
I'm using coginit and cogstop. Inside the new cog is a timer, and while the timer is running the cog won't shut off using cogstop. Is there a way to make the cog stop even though it is executing an instruction or can the new cog only stop between instructions?
Thanks!
    edited 2012-05-14 14:54
    cogstop should work regardless of what the cog is doing. How do you know the cog isn't stopping? Show us some code, please.
  • xanaduxanadu Posts: 3,347
    edited 2012-05-14 15:02
    I know the cog isn't stopping because it's panning a camera. I wrote a remote control for a pan tilt servo base. Then I added a pre-programmed 'patrol' mode where it swings from side to side automatically. While panning to the next position and I stop the new cog the camera continues to pan until the preset is reached. Then I can take control.
        "z", "Z":
           coginit(4,patrol, @stack[0])           'camera patrol mode on
           xbee.str(string(" Cam Patrol On "))
         "c", "C":
           cogstop(4)                                  'camera patrol mode off
           xbee.str(string(" Cam Patrol Off "))
    The above code listens for z or c character on XBee.
    pub patrol
     servo.set(2, P_POS1, 2) 'init pos
     servo.set(3, T_POS1, 2)
     pause (15000)
       repeat
        servo.set(2, P_POS2, 2)
        P_POS := P_POS2         'sync
        pause (30000)
        servo.set(3, T_POS2, 2)
        T_POS := T_POS2          'sync
        pause (5000)
        P_POS := P_POS1        'sync
        pause (30000)
        T_POS := T_POS1         'sync
        pause (5000)
    The above code moves the pan tilt servos to predefined positions.
    Thanks a lot!
    edited 2012-05-14 15:10
    Maybe this;
    repeat until P_POS2 := P_LIMIT
        P_POS2 := P_POS2 + 1
    That way it's not waiting until the end like below?
    repeat
        P_POS := P_POS2
        pause (30000)
  • JonnyMacJonnyMac Posts: 9,457
    edited 2012-05-14 15:49
    If you're panning a camera it's likely you have servo cog in use and that continues. What you might want to do is have this cog monitor a shutdown flag that is stored the hub. Your main program would set this flag and on reading, the cog could handle any required maintenance and then shutdown cleanly. I do this with my audio play object so that it can be stopped while the file is playing or looping.
    [Edit] Am I mistaken or is that my servo object (jm_servo8_adv) you're using? That would explain why the servo doesn't stop -- the movement to destination is still in progress. Maybe I should add a halt method that will stop the servo where it is.
    edited 2012-05-14 15:51
    This cog cannot be stopped while in motion either:
    pub patrol
      repeat until P_POS == P_POS2     'P_POS pan current position, P_POS2 pan limit right
         servo.set(2, P_POS, 2)               'move the pan servo to the limit
         P_POS := P_POS + 1                'slowly
    I thought that without the pause the cog has to stop instantly because it's going line to line fast.
    Here is how I'm stopping the cog:
    edited 2012-05-14 16:00
    JonnyMac wrote: »
    Hey JM thanks, I'm using your servo object. Working great again on yet another project. What you said makes sense I hadn't even thought about the servo object. I'm still really confused about why shutting down my cog that calls your object wouldn't stop the servo though. I'm trying to write a demo code not involving servos just LEDs and timers to work it out.
    edited 2012-05-14 16:11
    Keep in mind that you are running the servos very slowly by specify a speed differential of 2us/S -- the servo driver will keep moving a channel until the servo is at the desired target.
    Add these to methods to your copy of the object:
    pub halt(ch)
    '' Halts servo at current position
    '' -- allows iteruption of programmed move
      if ((ch => 0) and (ch =< CH_LAST))                            ' legal channel?
        target[ch] := pos[ch]                                       ' set target to current pos
    pub halt_all
    '' Halt all servos at current position
      bytemove(@target, @pos, 8)                                    ' update all targets
    Then you can update you patrol method to look like this -- it's more work, but it allows the method to stop the servos before committing on-demand hari-kari:
    pub patrol | t
      pause (15000)
      repeat
        t := cnt
        repeat 30000
          waitcnt(t += clkfreq / 1_000)
          if (killpatrol == true)
            servo.halt(2)
            servo.halt(3)
            cogstop(cogid)
        t := cnt
        repeat 5000
            servo.halt(2)
            servo.halt(3)
            cogstop(cogid)
        t := cnt
        repeat 30000
            servo.halt(2)
            servo.halt(3)
            cogstop(cogid)
        t := cnt
        repeat 5000
            servo.halt(2)
            servo.halt(3)
            cogstop(cogid)
    There may be a way to make this more elegant but without the full listing and understanding the intent, I'm taking the easy route. Of course, killpatrol is a global variable. You need to set this back to false before relaunching patrol.
    edited 2012-05-14 16:21
    Here's a slightly more elegant version of patrol():
    pub patrol | idx, delay, t
      idx := 0
      repeat
        case idx
          0:
            delay := 15_000
          1:
            P_POS := P_POS2
            delay := 30_000
          2:
            T_POS := T_POS2
            delay := 5_000
          3:
            P_POS := P_POS1
            delay := 30_000
          4:
            T_POS := T_POS1
            delay := 5_000
        t := cnt
        repeat delay
            servo.halt(2)
            servo.halt(3)
            cogstop(cogid)
        idx += 1
        if (idx == 5)
          idx := 1
    edited 2012-05-14 16:41
    I was not keeping in mind the speed I was running it at and now I'm starting to see why things are happening. Thanks a bunch, I added the halt to your object and tested it and it stops the servos. It is working great now just by calling;
           servo.halt(2)
           servo.halt(3)
           cogstop(4)
    I'm adding in the method, by your example so I can keep the vars in sync for coming out of patrol into manual, otherwise I'd probably just do the above only.
    Thanks!!
    JonnyMac wrote: »
      idx := 0
      repeat
        case idx
          0:
            delay := 15_000
          1:
            P_POS := P_POS2
            delay := 30_000
          2:
            T_POS := T_POS2
            delay := 5_000
          3:
            P_POS := P_POS1
            delay := 30_000
          4:
            T_POS := T_POS1
            delay := 5_000
        t := cnt
        repeat delay
            servo.halt(2)
            servo.halt(3)
            cogstop(cogid)
        idx += 1
        if (idx == 5)
          idx := 1
    Or I'll just use this... hehe thanks!
