Clock Freq
I have an application that needs a reasonably jitter-free variable frequency. I have read the application note and thus realise that jitter depends on the pll settings etc and can be avoided (to some extent) with some ratios. My application requires very small changes in frequency (0.5Hz) at high frequencies (10MHz).
Ideas:
1) Could I fool the Prop by telling it that my crystal frequency (clkfreq) was something other that it actually is to make sure that the frequency I need is a "sweetspot"?
2) Can I dynamically re-define the Prop's "clock freq" in the code to move the sweetspot a little?
3) If all else fails I guess that I could use a hardware method to pull the actual crystal freq.
Thoughts from Propellor-land?
Regards
Richard
Ideas:
Regards
Richard
Alan (ex g8lcu)
Flip this into the time domain : you are asking for 100ns, for the 10MHz, which so far sounds easy, but that 0.5Hz, is 0.05ppm,
or expressed in time, you want 99.9999950000002499999 ns - yes, that's 5 femto seconds steps you are asking for.
(google low jitter clocks, to get an idea of real jitter numbers, from the best sources. )
Something running at 12.5ns, is going to have shiploads of jitter, relative to 5fs.
How many of those 0.5Hz steps do you need ? A VCXO may be the best high purity solution ?
Are you looking to modulate a signal or does the frequency have to be stable long-term to 0.5Hz accuracy?
@jmg People are already using the prop with 2Hz shifts at 10MHz for ham radio applications:
http://ko7m.blogspot.co.uk/2012/01/wspr-on-propeller.html
I was just thinking of ways to get the shifts closer to what is required by the modulation method (actually 1.5Hz - not 0.5Hz as I originally thought). You are right about the VCXO of course but I was just wonedring what could be done to improve the "prop standalone solution".
Thanks all.
Any more thoughts?
Regards
Richard
"No" to questions 1 and 2, because they don't change anything physically, so the oscillation with a given frqa will be the same regardless. And it's the value of frqa that determines how much jitter there is. As to question 3, yes you could add a cap to the crystal circuit and pull the frequency a bit. The Propeller itself would have no way of knowing how much it's being pulled, though, because it'd be pulling its own timebase. However, I'm sure this is something you could calibrate ahead of time.
I've done some work with a Propeller-mediated DPLL that you might find useful, here:
You can apply the same principle to the local oscillator in mixers such as the SA602 or '612.
I always tell people that you can't filter out oscillator jitter, once it's produced, since the vestigial sidebands it produces are so close to the fundamental. However, your case might be an exception, since your frequency is fixed, and your modulation range is so narrow. I wonder if a crystal lattice filter could be tuned sharply enough to provide a passband only a few Hertz wide.
-Phil, AD7YF
So you are trying to do the same thing ? send 683ms duration, of one of 4 frequencies, ~1.5Hz spaced ?
(I think 10.000MHz is in the very centre of the 4 ? so you never send exactly 10.000)
That link 'works' because they ignored the spectrum - see Phil's link.
You don't really want to be radiating in a broad splash, so a cheap VCXO would give the best results, and the Prop could lock that to a better OCXO or GPS reference pulse, if the 10.000MHz average is important.
PLL chips also have better spectrums, but are a very big hammer. The Si5351 we have played with, this has a sub GHZ Vco, and is relatively cheap, but the better ones have VCOs in the some-GHz region, and they have better spectrums.
Given you know the Centre F and the small dF is nicely within a VCXO, and they are cheap, why not do it properly ?
Edit: Checking into TXCO/VCXO, it seems 10MHz is giving way to 20MHz in the smaller models.
This nice one, is ~$3.50/100+ from Digikey (535-9702-1-ND)
http://www.abracon.com/Oscillators/ASVTX-09.pdf
At 0.5ppm with a 8ppm pull range, this is good for many precise projects.
The clipped sine out may need a 1GU04 buffer, or maybe the Xtal buffer is enough ? (set to Max Speed?)
Or, the 74HC6323 can be used to both amplify, then divide to a square wave drive.
3V supply allows for a small RC filter from 3v3.
The pull range gain is only broadly defined, so a gain-calibrate step would be needed, min gain looks like 8ppm/V, so the (extremely) narrow band FM in the link above, of 146.48ppb/step, is a modulation control dV of ~18.31mV.
Abracon do not give a modulation bandwidth, but TAITIEN mentioned 10KHz on their vTCXO, which is no problems to support slow 683ms bit timings.
The Prop can manage Calibrate and DAC, if you want to lock within that 2.5ppm, the modulation is about 6% of the lock voltage (+/- 312mv about 50% of Vdd )
As a very crude experiment, I let the Propeller do the "mixing" by outputting both signals to the same pin, effectively ORing them:
CON _clkmode = xtal1 + pll16x _xinfreq = 4_915_200 OUT_PIN = 0 PUB start | time ctra := %00100 << 26 | OUT_PIN ctrb := %00100 << 26 | OUT_PIN dira[OUT_PIN]~~ frqa := frq_val(9_830_400) frqb := frq_val(169_600) repeat PRI frq_val(frq) : r '' Compute the required value of frqx to obtain the frequency frq. repeat 32 frq <<= 1 r <<= 1 if frq => clkfreq frq -= clkfreq r++This produced the waveform shown, with the expected mess of "mixer" products:
Here's what it looks like zoomed in on the fundamental frequency.
Next, I constructed a simple narrow-band filter with some parallel-resonant (20 pF) 10 MHz crystals I had:
Here is what the output and broad spectrum look like:
Here's the zoomed-in spectrum:
You will probably obtain even better results doing the mixing externally in an SA602/612. But at least, the principle appears to be sound, with spurious frequencies more than 40dB down in my crude experiment (on a solderless breadboard, no less).
By this time next week (hopefully), I should have a better spectrum analyzer and will repeat the experiment to see if there are any hidden gotchas that don't show up here.
Some nice footwork. Is that filter out voltage over 3V p-p ? Who needs a SA602 ?
Uses 5 generic crystals, but may still need a lock ? (varicap on the 4.9152MHz, or maths adder on the 169.6 KHz ? )
Another modulator choice is a XOR gate - be interested to compare the filter out voltage from OR and XOR choices.
Could a series RC as first stage, allow removal of a Crystal stage ?
I can see one fish-hook in this approach, and that is even at the slow modulation rate, the numbers may not quite stack up ?
The NCO granularity/frame rate, is of the same order as the modulation size and speed, so will the quantize noise, compromise demodulation ?
Demodulation of this is asking for resolve of just +1/+2/-1/-2 whole cycles, in the 682.687ms frame.
http://wsprnet.org/drupal/wsprnet/map
regards
Richard
