P8X32A Real Time USB While Executing Program
Can the P8X32A be used as an interface between an electronics project and the USB port of my laptop computer ?
Can the propeller use the USB while executing it's program or is the USB only useful for programming the propeller.
I want my electronics project to communicate with my PC through the USB port, can the P8X32A be used as a parallel to USB interface ?
Yes it certainly can, although it could possibly be a waste of resources when there are other chips out there more suitable for that partticular task.
Jeff T.
http://www.leonheller.com/usb/index.html
WaffenGeist,
It depends on what you mean by "interface".
The Propeller communicates with the PC through a FTDI chip. A common way for the Propeller to be programmed is using the FTDI chip. The chip can also let the Propeller communicate with the PC while it is running a program. The PC treats the interface as a serial connection.
To use the Propeller as a parallel to USB addapter, would depend a lot on the amount of data to be transfered and if there were a program on the PC to use the data coming over the serial line. I don't know if there is a way to trick a PC into thinking the serial data is parallel or not (I kind of doubt it if you use the FTDI chip).
