Address Passing
I'm trying to debug a problem with addresses on the Propeller. Given the code below, I expect the addresses to match on all three outputs. But they don't! Somehow, the value is getting modified when it is passed to the imu.add_register function.
What's going on here?
IMU Object:
Output:
I'd expect to see the address of F3C for hub_address, but instead it's the address of something else. What is going on here?
I've attached the original source, although it is a bit messy. What is above is what is run.
{ main object }
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
CON
'IO Pins
DEBUG_TX_PIN = 30
DEBUG_RX_PIN = 31
IMU_RX_PIN = 0 'Note: direction is from Propeller IO port
IMU_TX_PIN = 1 'Note: direction is form Propeller IO port
'Settings
VAR
byte um6_packet[20] 'Note: should require only 18 bytes, but extra just in case...
long gyro_proc_xy
long accel_proc_xy
long mag_proc_xy
long euler_phi_theta
OBJ
debug : "FullDuplexSerialPlus.spin"
imu : "um6.spin"
PUB Main | i, t1, addr, roll, pitch
addr := @euler_phi_theta
debug.start(DEBUG_RX_PIN, DEBUG_TX_PIN, 0, 230400)
waitcnt(clkfreq + cnt)
debug.str(string("Starting", 10, 13))
t1 := imu.add_register($62, addr)
debug.str(string("hub_address: "))
debug.hex(t1, 8)
debug.tx(10)
debug.tx(13)
debug.str(string("addr: "))
debug.hex(addr, 8)
debug.tx(10)
debug.tx(13)
debug.str(string("@euler_phi_theta: "))
debug.hex(@euler_phi_theta, 8)
debug.tx(10)
debug.tx(13)
IMU Object:
{ imu object }
PUB add_register(register, hub_address)
return hub_address
Output:
Starting hub_address: 33E883C4 addr: 00000F3C @euler_phi_theta: 00000F3C
hub_address long [COLOR="#FF0000"]{no value}[/COLOR] 'Location in the hub to store the data. ... has_data res 1 'length of the received packetThat was it! Thank you!
The problem here is that it compiles under BSTC (but I assume not the Prop Tool?). As soon as I changed it so the parameter and pasm_label have different names I get the correct result.
I'm curious what happened though.
Where $1 is the filename. Even when I remove the -f -p0 and -l options it will compile.
Thanks for the explanation.
