Update for un-usable SD Cards
Gigaware 4GB microSDHC card does not work with the Prop BOE card reader
Barcode # 40293 02170
P/N 54-55-04358
SKU # 44-208
Vendor = Best Buy
That's all I have found so far.
P/N 54-55-04358
SKU # 44-208
Vendor = Best Buy
I don't have any SD cards (and I have a lot) that don't work with the Propeller. I have had several that needed to be reformatted (the slow way) before they would work.
I usually use Kye's SD driver.
As Duane mentioned don't use the "Quick" method.
-- Gordon
I don't think we take too much for granted from anyone since even people who use these all the time can overlook something. I seem to recall there were certain versions of the SD card drivers that worked better than others. There may be older versions floating around out there and I believe that is why the question was asked what version specifically (version, date, etc) in case you should be using a newer version that perhaps has a bug fix. It's been a while since I've looked for the latest SD drivers myself but I do plan on it since I want to use them in an upcoming project.
Robert
I' ve heard the Gigaware product is rebranded for RadioShack, and that they are actually SanDisc. I've used 4GB SanDiscs in the PropBOE, so either these are different cards internally. RS does not list what class these cards belong to. That's important for SDHC cards. If you buy an HC card and it doesn't list its class, best pass on it. Best Buy online does not list the card you mention, either by part, SKU, or brand.
-- Gordon
