Help with Bothservosthreeseconds.bs2 example.
Hello,
I was recently gifted a BOE-bot kit and I have very much enjoyed working through the activity book, however I have hit a bit of a stumble point.
The program example BothservosThreeSeconds.bs2 gives the code:
DEBUG "Program Running!"
counter VAR Byte
FOR counter = 1 TO 122
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
PULSOUT 13, 850
PULSOUT 12, 650
PAUSE 20
NEXT
END
...which is supposed to make the two servos rotate in opposite directions and then change directions, however both servos will only rotate in the initial directions indefinitely and the debug console will continuously print "Program running!". I'm especially confused because if I omit one of the servos from the loops then the other will behave as it should. Can anyone offer some insight into what I'm doing wrong?
counter VAR Byte
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
PULSOUT 13, 850
PULSOUT 12, 650
PAUSE 20
NEXT
END
