mini a/c unit temp control
Ok so basically I have some exotic pets that need to be within a certain temp range to survive. I am building a peltier plate mini a/c unit to cool the general area they are in instead of running my a/c all day for the whole house. The a/c peltier unit is the easy part.....the not soo easy part is temp control for me. I have a basic stamp 2 Home Work Board. I would like to control temp through process control..basically meaning (if temp drops below or above said temp do X) I was thinking of using an LM34 using http://airchild2.tripod.com/Thermo.html as a method for ad conversion. Having never played with any sensors before I am a little lost on what all this means and where to begin. Any help would be appreciated guys!
Take a look at the DS1620 (in stock at the Parallax Store.) Page 161 of the Stampworks V2.1 has an experiment using it. I was able to use this chip and a BS2 to make a thermostat that controlled a camper A/C unit via X-10 control of a 115 VAC socket. You can set the temp you want to maintain.
falcon
After reviewing I answered my own question, it needs my stamp for processing the temps. Is this correct?
Actually, you can use the BS2 to program the High/Low thresholds to the DS1620 and then disconnect from the Stamp to work by itself. See example on page 166 of the StampWorks Manual.
I have used a programmed DS1620 stand alone to run a SSR for an attic fan. No need for the BS2.
Jim
