Just finishing up with Basic Stamp Activity Kit.
khumfreville
So I'm just finishing up with the Basic Stamp Activity Kit, using the HomeWork board and the BS2, and I came up with an idea of a practical thing to make using it. I built my prototype using the HomeWork board, and now I'm getting ready to put the final draft together.
I have a few concerns though: because the design is so simple (just a sensor and an LED), I feel like using the BS2 for the job is a bit over-doing it. I'm only using the 2 of the 16 available I/O pins. Is there a better option for me than the BS2, which will be grossly put to waste in such a product?
Thanks in advance, for everything!
But here's an analog distance sensor:
http://www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/CategoryID/51/List/0/SortField/0/Level/a/ProductID/776/Default.aspx
It outputs a voltage proportional to get distance. You could use that voltage coupled with a comparator IC to turn on the LED at the trigger point.
Thanks again!
