TVS diodes for ESD protection - I need help
Hello,
my current project involves a Prop and SIMCOM SIM908 (GSM/GPRS/GPS) module. All components ordered and are on the way.
SIMCOM recommendation is to use ESD protection on SIM card bus such as SMF05C or equivalent, and I'm not able to obtain it.
SMF05C General Spec:
Now my questions are:
- Can it be replaced with this one:
- Do I rely need it(Can it be omitted from circuit)?
Once when I finish this project I'll share it with forum community.
Thank you in advance!!
Peak Pulse Power (tp = 8/20μs): 100 Watts
Peak Pulse Current (tp = 8/20μs): 8 A
ESD per IEC 61000-4-2 (Air) / ESD per IEC 61000-4-2 (Contact): 20 / 15kV
Reverse Stand-Off Voltage: 5V
Reverse Breakdown Voltage: 6V
Clamping Voltage: 9.8 V
Junction Capacitance:130 pF
Datasheet: http://www.semtech.com/images/datasheet/smf05c.pdf
ORDIODE, TVS, 5V, 400W, UNI, 5%, SMA
Reverse Stand-Off Voltage Vrwm:5V
Breakdown Voltage Range:6.4V to 7V
Diode Configuration:Unidirectional
Peak Pulse Current Ippm:35A
Diode Case Style: DO-214AC
No. of Pins:2
Power Dissipation Pd:400W
SOURCE: http://www.ebay.com/itm/SMAJ5-0A-DIODE-TVS-5V-400W-SMA-UNI-5-x2pcs-/300610964578?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item45fdcf4c62
OR maybe this one:Reverse Stand-Off Voltage Vrwm:5V
Clamping Voltage Range:9.8V-5A / 15.5V-23A
Junction Capacitance:230-400 pF
Power Dissipation Pd:300W
SOURCE: http://www.ebay.com/itm/1-X-SMF5-0AT1G-TVS-DIODE-200W-5V-Pb-Free-/250980039305?pt=LH_DefaultDomain_0&hash=item3a6f937a89
- Can you suggest better option(s)?Fairchild Semiconductor 1500W 5V Transient Voltage Suppressor Diode, Part Number: SMCJ5V0A in SMC Package.
Reverse Stand-off Voltage Vrwm: 5V
Break Down Voltage Vbr: 6.4V min, 7.0V amx.
Peak Pulse Current Ippm: 163A
Reverse Leak Current Ir: 1mA
SMC Package
Detail Spec see Data Sheet at:
http://www.fairchildsemi.com/pf/SM/SMCJ5V0A.html
SOURCE:http://www.ebay.com/itm/Fairchild-1500W-TVS-Diode-5V-SMCJ5V0A-SMC-New-50pcs-/150207217200?pt=LH_DefaultDomain_0&hash=item22f90c3e30
FF
