newbie: prop math with negatives, etc...
I've been programming various stuff for years, but this is my first propeller project. I'm having some issue with what seems to be fairly basic math. I've been playing with this for 3 nights now and I think i'm stuck. I have a feeling that this has something to do with sign extension or variable size conversion. it seems to have issues with negatives. the odd thing is it works for some color combinations, but not others.
This is a christmas light project for controlling individually controllable strings of RGB leds. I'm working on SanDevices e681 pixel controller board, and using his 2.06 source code as a starting point. His board is intended as a ethernet e1.31 bridge and protocol translator for different types of pixel strings. it's designed to take the data from a pc streaming a data feed. I'm adding in code for user customizable internal patterns for basic stuff, for those of us who aren't ready for PC based sequencing yet.
what i'm trying to do with this is a fading chase.
If i have a pattern of Red Green Blue White, it would be stored in PatColor as 255 0 0 0 255 0 0 0 255 255 255 255 my code seems to work with this combination.
If I use Green, Lt Green, White, Lt Green i'm using 0 255 0 64 255 64 255 255 255 64 255 64. this is giving weird problems because the fades seem to sometimes go in the wrong direction and roll over the byte size limits.
PatColor is a BYTE array of 12 bytes that store R G B values (0-255) for up to 4 pixels. this is the user defined parameters
PatTempColor is a byte array of 15 bytes that store the same as above, but is larger by one pixel. this is used to do the shift and rotate, e.g. move everything right by 3 and copy bytes 12-14 to 0-2
these first two will always hold a positive value from 0-255.
patBlendDelta is a array of 12 LONGs, it stores the difference of each color channel of a pixel, with the same color channel of the next pixel, and divided by the number of steps. this should be a number between -255 and +255.
then i take this number and multiply by the current step. and add it to the PatTempColor variable.
here's the relevant declarations:
Thanks in advance for your help
--Jon--
BYTE PatColor[12] '**JC** colors for pattern pixels (R1 G1 B1 R2 G2 B2 etc...)
BYTE PatPixels '**JC** number of pixels to include in the pattern 1-4
BYTE PatFirstRun 'flag to test if it's the first time thru the pattern
BYTE PatRGBctr 'used for counting thru 3 colors of each pixel
BYTE PatPixCtr 'used for counting thru up to 4 pixels used in a pattern
BYTE PatStepCtr 'used for counting steps in a pattern AND for intermediate delay steps to skip pattern logic while checking webserver
BYTE PatTempColor[15] 'used for chasing pattern
LONG PatBlendDelta[12] 'temp array used for fading chase patterns
BYTE PatBlendTemp[12] 'temp used for fading chase patterns
and the code section:
PatSteps:=16 'constant for testing, number of fade steps
IF PatFirstRun==1 'check first run flag to initialize pattern for first iteration.
PatSetPixels(0) 'copy color params into dmx buffer and fill.
PatStepCtr:=0 'init step counter.
ByteMove(@PatTempColor,@PatColor,PatPixels*3) 'copy pixel color parameters to temp buffer
case PatStepCtr
0:
bytemove(@PatTempColor+3,@PatTempColor,PatPixels*3) 'shift pattern colors right 1px in temp buffer
ByteMove(@PatTempColor,@PatTempColor+PatPixels*3,3) 'copy last position into first. aka rollover
debug.str(string(CR,CR,"PatTempColor: "))
repeat _temp from 0 to (PatPixels*3)-1
debug.str(string(" "))
debug.dec(PatTempColor[_temp])
debug.str(string(CR,"PatBlendDelta: "))
repeat PatPixCtr from 0 to (PatPixels*3)-1
PatBlendDelta[PatPixCtr]:=(PatTempColor[PatPixCtr]-PatTempColor[PatPixCtr+3]) / PatSteps 'get color difference for each color on all px and divide by number of steps and store in blenddelta array
debug.dec(~PatBlendDelta[PatPixCtr])
PatStepCtr++ 'increment to next step
1..PatSteps:
debug.str(string(CR,"Step: "))
debug.dec(PatStepCtr)
PatBlendTemp[PatPixCtr]:=PatTempColor[PatPixCtr]-(PatBlendDelta[PatPixCtr] * PatStepCtr) 'add blendDeltaValue * step number to previous color value and store in BlendTemp array
debug.dec(PatBlendTemp[PatPixCtr])
ByteMove(@DMXbuffer,@PatBlendTemp,PatPixels*3) 'copy blendtemp array into first set of pix in dmxbuffer
PatFillPixels(0) 'Fill rest of buffer from first bytes
pausemsec(PatStepTime) 'delay pause to slow fade steps
OTHER:
ByteMove(@DMXbuffer,@PatTempColor,PatPixels*3) 'copy temp buffer to dmxbuffer for full pix values before moving to next pixel.
pausemsec(PatDwellTime*10) 'delay pause before next fade sequence.
PatStepCtr:=0 'increment to next step
--Jon--
