Comments and suggestions for improvement of demo object
Hi Everyone!
I have just finished translating the EarthLCD - ezLCD 301 app note for the BS2 into SPIN and I am looking for comments and suggestions for improvement. I intend on posting this in the OBEX when finished and would like this object to be self-explanatory and easy to use. The object is thoroughly tested and works like a charm. Any help would be appreciated!
''* ezLCD-301 application note from bs2 *
''* Author: *
''* Translated to SPIN by Joe Heinz *
''* Copyright (c) 2012 EarthLCD.com *
''* See end of file for terms of use. *
{-----------------REVISION HISTORY-----------------
v1.0 - x/x/2012 first official release.
ezLCDtx = 1 'The ezLCD tx pin (RX pin on prop) , change as needed
ezLCDrx = 0 'The ezLCD rx pin (TX pin on prop) , change as needed
ezLCDbaud = 9600 'the ezLCD baud-rate , change as needed
pinOut = 22 'This is the pin to toggle on and off , change as needed
pstBaud = 115200 'This is the baud-rate for Parallax Serial Terminal Debugger , change as needed
VAR
byte serStr[6], idx, c 'define a 6-byte string array for storing the data received from ezLCD
OBJ serial : "FullDuplexSerial" 'This object does the actual serial communication with the display *Thanks Chip Gracey, Jeff Martin
wait : "timing" 'This object is for simple timing *Thanks Parallax
pst : "parallax serial terminal" 'This object is for debugging to PC, comment out if not used *Thanks Jeff Martin, Andy Lindsay, Chip Gracey
PUB BOOT ''This method runs at startup
serial.start(ezLCDrx,ezLCDtx, 0, ezLCDbaud) 'Start fullDuplex serial driver with ezLCD pins @ ezLCDbaud, mode 0. Returns false if no cog available.
pst.start(pstBaud) 'Start Parallax Serial Terminal @ pstBaud, comment out if used
dira[pinOut] ++ 'Make pinOut an output
serial.str(string("cls black")) 'Clears the display to black
CR_LF 'Send Carriage Return + Line Feed
wait.pause1ms(10) 'Wait 10ms
serial.str(string("theme 1 9 3 0 0 0 8 8 8 8")) 'Defines Theme 1 for button 1
serial.str(string("theme 2 5 20 3 3 3 4 4 4 4")) 'Defines Theme 2 for button 2
serial.str(string("fontw 1 sans72")) 'define font for button 1 widget
serial.str(string("fontw 2 sans72")) 'defines font for button widget 2
serial.str(string("string 1 ON")) 'defines string for button 1
serial.str(string("string 2 OFF")) 'defines string for button2
serial.str(string("button 1 10 40 185 140 1 0 25 1 1")) 'defines button 1
serial.str(string("button 2 205 40 185 140 1 0 25 2 2")) 'defines button 2
wait.pause1s(3) 'Wait 3 Seconds for ezLCD to finish sending feedback about it's displays
serial.rxflush 'Clear serial receive buffer
pst.clear 'Clear parallax Serial Terminal, comment out if not used
' Main Loop starts here
repeat 'Repeat loop starts here
idx ~ 'Clear idx
repeat while (c:= serial.rx) <> 13 'Copy serial receive buffer into c and repeat until Carriage Return is received, CR signifies end of string from display
serStr[idx++] := c 'Move receive buffer into serStr then increment idx,
serStr[idx] ~ 'Set last byte to 0, for 0 terminated string to Parallax Serial Terminal
pst.str(@serStr) 'Send serStr to Parallax serial Terminal, comment out if not used
pst.newline 'Send newline to Parallax Serial Terminal, comment out if not used
if serStr[0] == "B" and serStr[1] == "P" and serStr[2] == "1" 'If received data is BP1 which means button 1 pressed
outa[pinOut] := 1 'then set pinOut high
if serStr[0] == "B" and serStr[1] == "P" and serStr[2] == "2" 'If received data is BP2 which means button 2 pressed
outa[pinOut] ~ 'then set pinOut low
serial.rxflush 'clear serial receive buffer for next iteration
bytefill(@serStr,6,0) 'clear serString for next iteration
PUB CR_LF ''Send Carriage Return + Line Feed
serial.tx(13) ' Send Carriage Return to display
serial.tx(10) ' Send Line Feed to display
I am also working on a low-level driver for the ez-lcd301 and been getting stuck. The object basically parses space-delimited, ASCII commands and parameters to something a bit easier to work with in spin. I keep getting strange errors with the returns and can't quite figure out what's going on. Full object :
''******************************************************************************************************************************************** ''* ezLCD-301 driver fro EarthLCD.com * ''* Author: Joe Heinz * ''* Copyright (c) 2012 EarthLCD.com * ''* See end of file for terms of use. * ''******************************************************************************************************************************************** '' documentation fix... PG 33, progress {id}{x}{y}{Width}{Height}{options}{max}{value}{theme} should read '' {id}{x}{y}{Width}{Height}{options}{value}{max}{theme} ''############################################################################################################################################ {-----------------REVISION HISTORY----------------- v0.0 - x/x/2012 first official release. } CON ''############################################################################################################################################ ''# Full Duplex Serial Settings # # ''# # ''# LCDtx = 1 Set this to match the ezLCD tx pin (RX pin on prop) # ''# LCDrx = 0 Set this to match the ezLCD rx pin (TX pin on prop) # ''# LCDbaud = 67500 Change this to match the intended baudrate to the display # ''# # ''# # ''# # ''############################################################################################################################################ ''# Command Table # ''# # rst = 29 'Reset command clsc = 2 'Clear command png = 3 'Ping command vrb = 106 'Verbose command bri = 5 'Brightness command col = 6 'Color command colid = 7 'Color ID command fnt = 10 'Font command fntw = 11 'Fontw command fnto = 12 'Fonto command thresh = 105 'Threshold command lnw = 13 'LineWidth command lntyp = 14 'LineType command xycmd = 15 'XY command xyidcmd = 41 'XY ID command strcmd = 16 'String command plotcmd = 17 'Plot command linecmd = 18 'Line command boxcmd = 19 circmd = 20 arccmd = 21 piecmd = 22 piccmd = 24 prntcmd = 25 clpen = 46 clpar = 47 rcd = 30 ply = 31 stp = 32 wt = 102 pse = 33 lp = 34 spd = 35 dl = 58 rn = 57 chd = 52 mkd = 53 rmd = 58 rmod = 54 morecmd = 59 cp = 56 dircmd = 55 fmt = 60 sct = 40 cm = 62 cfi = 37 iocmd = 38 cwdcmd = 51 ''# # ''############################################################################################################################################ ''# General Settings # LT = 13 buffersize = 65 ''# # ''############################################################################################################################################ ''# # VAR long bufferAddress ' byte incoming[buffersize] OBJ serial : "FullDuplexSerial" 'This object does the actual serial communication with the display PUB null 'not a top level object PUB INIT(LCDtx,LCDrx,LCDbaud,BufferPointer) '' Start ezLCD 30x driver, Returns the COG number of FullDuplexSerial or False if no cog available result := serial.start(LCDrx,LCDtx, 0, LCDbaud) 'Start fullDuplex serial driver with ezLCD pins @ ezLCDbaud, mode 0. Returns false if no cog available. bufferAddress := BufferPointer 'copy buffer address to main memory PUB RESET '' Reset ezLCD as if it was just turned on LCD_CMD(rst) 'send reset command to display PUB CLS(c) '' Clear display to color and clear widgets ifnot c < 200 and c > -1 'check to make sure color is valid, 0 - 199 c := 0 'if not set c = 0 LCD_CMD1(clsc,c) 'send CLS command to display with color PUB PING '' Asks LCD to send acknowledge with pong, Returns the response from the display LCD_CMD(png) 'send "PING" command to display result := serial.rx - 48 'return lcd response PUB LIGHT(brightness) '' Set backlight level to brightness when 0 - 100 (as percent) *default is 75%. If brightness = -1, returns the current brightness as ASCII 0-terminated STRING to buffer in main memory if brightness > -1 and brightness < 101 'check to make sure brightness is between 0 and 100 (as percent) LCD_CMD1(bri,brightness) 'send "LIGHT" command to display with brightness elseif brightness == -1 'if brightness = -1 LCD_CMD(bri) 'send "LIGHT" command result := GetString 'pass string to buffer in main memory and set result to string size ' *** Tested OK *** '_________________________________________________________________________________ PUB COLOR(CID) '' Set current color to COLORID (0 - 199). If CID = -1, Returns current color to buffer in main memory and set result to string size. Returns 0 if good, -1 if incorrect color is given if CID < 200 and CID > -1 'if CID = (0 - 199) LCD_CMD1(col,CID) 'send "COLOR" command to display with "c" elseif CID == -1 'if CID = -1 'LCD_CMD(col) 'send "COLOR" command to display serial.dec(6) 'send "cmd" command to display CR_LF 'send CR + LF to display result := GetString 'pass string to buffer in main memory and set result to string size else 'otherwise result := -1 'set result to -1 PUB COLORID(index,R,G,B) '' Set COLORID[index] to RGB value. IF R = -1, Returns the color values of COLORID[index] if R == -1 'if r = -1 LCD_CMD1(colid, index) 'send "COLORID" command to display result := GetString 'pass string to buffer in main memory and set result to string size else 'otherwise LCD_CMD4(colid,index,R,G,B) 'send "COLORID" command to display with "index" , "R" , "G" , "B" '' PUB FONTi(f) '' Use internal font (factory) "f", currently 0 and 2 = default medium font LCD_CMD1(fnt,f) 'send "FONT" command to display with "f" to display PUB FONTp(fontNamePointer) '' Use programmable font (ezf file) from flash drive LCD_STR(fnt,fontNamePointer) 'send "FONT" command to display with "fontName" @ Pointer PUB FONTw(index,fontNamePointer) '' Use programmable widget font (ezf file) from flash drive for each of 16 themes if index <> -1 LCD_D_S(fntw,index,fontNamePointer) 'send "FONTW" command to display with "index" and "fontName" @ Pointer else LCD_CMD(fntw) 'send "FONTO" command to display result := serial.rx - 48 'get font orientation from display, and return it as the result PUB FONTo(orientation) '' Set font orientation, 0 = Horizontal, 1 = Vertical. Other to Return Font orientation if orientation == 0 or orientation == 1 'If orientation is 0 or 1 LCD_CMD1(fnto,orientation) 'send "FONTO" command to display with "orientation" result := serial.rx - 48 else 'If orientation is NOT 0 or 1 LCD_CMD(fnto) 'send "FONTO" command to display result := serial.rx - 48 'get font orientation from display, and return it as the result PUB THRESHOLD(value) '' Set the value used for sensitivity of touch display, Default is 256 if value <> -1 'if value <> -1 LCD_CMD1(thresh,value) 'send "THRESHOLD" command to display with "value" else 'otherwise LCD_CMD(thresh) 'send "THRESHOLD" command to display result := GetString 'set result PUB LINEWIDTH(pixel) '' Sets line width to pixel width. 1 or 3 pixels wide. If invalid pixel width is passed, Returns line width from display if pixel == 1 and pixel == 3 'check for valid pixel width LCD_CMD1(lnw,pixel) 'send "LINEWIDTH" command to display with "pixel" else 'invalid pixel width returns current pixel width LCD_CMD(lnw) 'send "LINEWIDTH" command to display result := serial.rx - 48 'get "pixel" from display, and return it as the result PUB LINETYPE(type) '' Sets line type to solid, dot or dash. 0 = solid, number increases spacing between dots, -1 if type <> -1 'check for valid line width LCD_CMD1(lntyp,type) 'send "LINETYPE" command to display with "type" else 'otherwise LCD_CMD(lntyp) 'send "LINETYPE" command to display result := GetString 'return current type as the result PUB XY(x,y) '' Set drawing cursor to location x,y on display. x and y are checked to make sure they can fit on the display. Set x = -1 to return current X,Y if x <> -1 'check for set x,y LCD_CMD2(xycmd,x,y) 'send "XY" command to display with "x" and "y" else 'otherwise LCD_CMD(xycmd) 'send "XY" command to display result := GetString 'return current x,y to buffer in main memory and sets the string size as the result PUB XY_byName(xyNamePointer) '' Set drawing cursor to location x,y on display. x and y are checked to make sure they can fit on the display. '' 9 font justifications: LT, CT, RT, LC, CC, RC, LB, CB, RB offers convienient display placement options LCD_STR(xycmd,xyNamePointer) 'send "XY" command to display with "xyName" @ pointer PUB XYID(index,SavRes) '' Save X and Y into XY array using index if SavRes = 1, otherwise Restore X and Y from XY arrau using index serial.dec(xyidcmd) 'send "XYID" command to display serial.tx(32) serial.dec(index) 'send index to display if SavRes == 1 'if SavRes = 1 serial.tx(32) serial.dec(1) 'send "1" to display, signifies SAVE command CR_LF 'Send CR + LF PUB LCD_STRING(index,stringPointer) '' Store "string" @ stringPointer in the string array using index. If stringPointer = -1, recall string from index. Index = 0 - 61. Returns -1 if index is invalid if index > 0 and index < 62 'Check for valid index and if valid if stringPointer <> -1 'Check for Store / Recall and if Store LCD_D_S(strcmd,index,stringPointer) 'send "STRING" command to display with "index" and "string" @ Pointer else 'if Recall LCD_CMD1(strcmd,index) 'send "STRING" command to display with "index" result := GetString 'pass string to buffer in main memory and set result to string size else 'if invalid index result := -1 'set result = -1 PUB PLOT(x,y) '' Place a pixel at XY with current color. Will place pixel at current X,Y if X and Y are set to -1 if x == -1 and y == -1 'Check for X,Y set to -1 and draw pixel at current X,Y LCD_CMD(plotcmd) 'send "PLOT" command to display, draws at current X,Y else 'otherwise LCD_CMD2(plotcmd,x,y) 'send "PLOT" command to display with "x" and "y" PUB LINE(x,y) '' Place line from current X,Y to X,Y with current color and current width and curren type LCD_CMD2(linecmd,x,y) 'send "LINE" command to display with x and y PUB BOX(width, height, fill) '' Place a box from current X,Y with specified width and height. '' Fill = 1 or F to fill box or string starting with F. Box must be > 1 pixel wide if fill == "F" 'if fill = "F" fill := 1 'set fill = 1 LCD_CMD3(boxcmd,width,height,fill) 'send "BOX" command to display with "width", "height" and "fill" PUB CIRCLE(radius, fill) '' Draw circle at current X,Y with radius. Fill = "1" or "F" to fill circle if fill == "F" 'check if fill = "F" and if so fill := 1 'set fill to "1" LCD_CMD2(circmd,radius,fill) 'send "CIRCLE" command to display with "radius" and "fill" PUB ARC(radius, start, end, fill) '' Draw ARC with Radius, Start angle and End angle. Fill = 1 or "F" to fill arc. Angle of 0 is on the right if fill == "F" 'check if fill = "F" and if so fill := 1 'set fill to "1" LCD_CMD4(arccmd,radius,start,end,fill) 'send "ARC" command to display with "radius", "start", "end" and "fill" PUB PIE(radius, start, end) '' Draw PIE with Radius, Start angle and End angle. Angle of 0 is on the right LCD_CMD3(piecmd,radius,start,end) 'send "PIE" command to display with "radius", "start", "end" PUB PICTURE(x, y, options, index) '' Display PICTURE ID index on the LCD. File can be JPG, GIF or BMP. '' X,Y is the upper left corner of the image when no options are applied. '' Options : 1 = Align to center of display, 2 = down scale image to display, 3 = both LCD_CMD4(piccmd, x, y, options, index) ' send "PICURE" command to display with "x", "y", "options", "index" PUB PRINTi(index, justNamePointer) '' Print string in String Array pointed to by index to the display. '' 9 font justifications: LT, CT, RT, LC, CC, RC, LB, CB, RB offers convienient display placement options LCD_D_S(prntcmd,index,justNamePointer) 'send "PRINT" command to display with "index" and "justification Name" @ Pointer PUB PRINTs(stringPointer, justNamePointer) '' Print string in String Array pointed to by index to the display. '' 9 font justifications: LT, CT, RT, LC, CC, RC, LB, CB, RB offers convienient display placement options LCD_Str2(prntcmd,stringPointer,justNamePointer) 'send "PRINT" command to display with "index" and "justification Name" @ Pointer PUB CLIPENABLE(enable) '' Turn on clip enable area LCD_CMD1(clpen,enable) 'send "CLIPENABLE" command to display with "enable" PUB CLIPAREA(left, top, right, bottom) '' Set Clip Area to protect the surrounding area from change LCD_CMD4(clpar, left, top, right, bottom) 'send "CLIPAREA" command to display with "left", "top", "right" and "bottom" PUB RECORD(namePointer) '' Record marco "name" to internal flash drive under \EZUSER\MACROS\ LCD_STR(rcd,namePointer) 'send "RECORD" command to display with "name" @ pointer PUB PLAY(namePointer) '' Play macro "name", Looks in directory \EZUSER\MACROS first and if not found it looks in \EZSYS\MACROS\ LCD_STR(ply,namePointer) 'send "PLAY" command to display with "name" @ pointer PUB STOP '' Stop playing macro and close the file '' You may have to restart the display to see the files from the PC side LCD_CMD(stp) 'send "STOP" command to display PUB WAIT(optionPointer) '' Wait for events. Options "T" = Touch, "!T" = No Touch, "TR" = Touch and Release, "IO1-9" = Wait for 1, "!IO1-9" = Wait for 0 LCD_STR(wt,optionPointer) 'send "WAIT" command to display with "option" @ pointer PUB PAUSE(delay) '' Pause delay (msec) LCD_CMD1(pse,delay) 'send "PAUSE" command to display with "delay" PUB LOOP(onOff) '' Loop any macro that run. "1" = ON, "0" = OFF !!Loop should not be used in a macro.!! LCD_CMD1(lp,onOff) 'send "LOOP" command to display with "onOff" PUB SPEED(delay) '' Delay between macro line processing (msec) LCD_CMD1(spd,delay) 'send "SPEED" command to display with "delay" PUB DEL(namePointer) '' Delete file name @ namePointer, same as erase LCD_STR(dl,namePointer) 'send "DELETE" command to display with "name" @ namePointer PUB REN(namePointer1, namePointer2) '' Rename file name1 to file name2 using name pointers LCD_STR2(rn,namePointer1,namePointer2) 'send "RENAME" command to display with "name" @ Pointer1 and "name" @ Pointer2 PUB CD(directoryNamePointer) '' Change to directory LCD_STR(chd, directoryNamePointer) 'send "CD" command to display with "directoryName" @ Pointer PUB MD(directoryNamePointer) '' Make directory LCD_STR(mkd, directoryNamePointer) 'send "MD" command to display with "directoryName" @ Pointer PUB RD(directoryNamePointer) '' Remove directory LCD_STR(rmd,directoryNamePointer) 'send "RD" command to display "directoryName" @ Pointer PUB COPY(namePointer1, namePointer2) '' Copy file name1 to file name2 LCD_STR2(cp,namePointer1,namePointer2) 'send "COPY" commmand to display with "name" @ Pointer1 and "name" @ Pointer2 PUB FORMAT(passwordPointer, serialPointer, volumeLabelPointer) '' Format "ezLCD" volumeid serial.dec(fmt) 'send "FORMAT" command to display serial.tx(32) 'send "space" to display serial.str(passwordPointer) 'send name @ passwordPointer serial.tx(32) 'send "space" to display serial.str(serialPointer) 'send name @ serialPointer serial.tx(32) 'send "space" to display serial.str(volumeLabelPointer) 'send name @ volumeLabelPointer CR_LF 'send CR + LF PUB SECURITY(passwordPointer, stringPointer) '' Lock the flash drive so it can not be accessed from the PC LCD_STR2(sct, passwordPointer, stringPointer) 'send "SECURITY" command to display with "password" @ Pointer and "string" @ Pointer PUB CFGIO(gpio, type) '' Configure GPIO as input (0) or output (1), serial, spi, i2c if type == "I" 'if type = "I" type := 0 'set type = 0 elseif type == "O" 'if type = "O" type := 1 'set type = 1 LCD_CMD2(cfi,gpio,type) 'send "SCFGIO" command to display with "GPIO number" and "data" PUB IO(gpio,data) '' IO write GPIO (1-9) with data. Write data to peripheral if configured LCD_CMD2(iocmd,gpio,data) 'send "IO" command to display with "GPIO number" and "data" result := GetString 'pass string to buffer in main memory and set result to string size PUB CWD '' Returns current working directory LCD_CMD(cwdcmd) 'send "CWD" command to display result := GetString 'pass string to buffer in main memory and set result to string size PUB MORE(namePointer) '' Sends the content of the file name to the current console port LCD_CMD(morecmd) 'send "MORE" command to display result := GetString 'pass string to buffer in main memory and set result to string size PUB DIR(maskPointer) '' Returns directory using mask LCD_STR(dircmd,maskPointer) 'send "dir" command to display with "mask" @ Pointer result := GetString 'pass string to buffer in main memory and set result to string size ''############################################################################################################################################# ''# # ''# # ''# These methods need to be worked on # ''# # ''# # PUB THEME(themeIndex,embossDkColor,embossLtColor,textColor0,textColor1,textColorDisabled,color0,color1,colorDisabled,commonBkColor,tFontw) | idx ''Set widget theme info !NOTE tFontw requires Firmware Verion 1.06 or later! serial.dec(90) repeat idx from 0 to 10 serial.tx(32) serial.dec(themeIndex[idx]) CR_LF PUB AMETER_VALUE(id, value) LCD_CMD2(77, id, value) PUB ANALOG_METER(id,x,y, Width, Height, options, inital, maxn, themen, stringID) | idx serial.dec(76) repeat idx from 0 to 9 serial.tx(32) serial.dec(id[idx]) CR_LF PUB BUTTON(id,x,y, Width, Height, options, align, radius, themen, stringID) |idx serial.dec(70) repeat idx from 0 to 9 serial.tx(32) serial.dec(id[idx]) CR_LF PUB CHECKBOX(id, x, y, width, height, options, themen, stringID) |idx serial.dec(71) repeat idx from 0 to 7 serial.tx(32) serial.dec(id[idx]) CR_LF PUB CHOICE(stringPointer, themen) serial.dec(89) serial.tx(32) serial.str(stringPointer) serial.tx(32) serial.dec(themen) CR_LF PUB DIGITAL_METER(id,x,y,width,height,options,value,digits,dotpos,themen) |idx serial.dec(74) repeat idx from 0 to 9 serial.tx(32) serial.dec(id[idx]) CR_LF PUB DMETER_VALUE(id,value) LCD_CMD2(75,id,value) PUB GROUPBOX(id,x,y,width,height,options,themen,stringID) |idx serial.dec(72) repeat idx from 0 to 8 serial.tx(32) serial.dec(id[idx]) CR_LF PUB PROGRESS(id,x,y,width,height,options,position,range,themen) |idx serial.dec(85) repeat idx from 0 to 8 serial.tx(32) serial.dec(id[idx]) CR_LF PUB PROGRESS_VALUE(id,value) LCD_CMD2(86,id,value) PUB RADIO_BUTTON(id,x,y,width,height,options,themen,stringID) | idx serial.dec(73) repeat idx from 0 to 7 serial.tx(32) serial.dec(id[idx]) CR_LF PUB STATIC_TEXT(id,x,y,width,height,options,frame,themen,stringID) | idx serial.dec(87) repeat idx from 0 to 8 serial.tx(32) serial.dec(id[idx]) CR_LF PUB STATICTEXT_VALUE(id,stringPointer) LCD_D_S(88,id,stringPointer) PUB AMETER_COLOR(id,color1,color2,color3,color4,color5,color6) | idx serial.dec(78) repeat idx from 0 to 6 serial.tx(32) serial.dec(id[idx]) CR_LF PUB DIAL(id, x, y, radius, options, resolution, inital, maxn, themen, stringID) | idx serial.dec(80) repeat idx from 0 to 9 serial.tx(32) serial.dec(id[idx]) CR_LF PUB SLIDER(id, x, y, width, height, options, range, resolution, value, themen) | idx serial.dec(82) repeat idx from 0 to 9 serial.tx(32) serial.dec(id[idx]) CR_LF PUB CheckWidget | w,i,d ''Returns last widget change if GetString case byte[bufferAddress] "0" : w := 0 d := 0 "-" : w := 0 d := -1 "1" : w := 0 d := 1 "B" : w := 1 i := (byte[bufferAddress][1] - 48) if byte[bufferAddress][2] == "P" d := 1 else d := 0 "C" : w := 2 i := byte[bufferAddress][1] if byte[bufferAddress][2] == "C" d := 1 else d := 0 "R" : w := 4 i := byte[bufferAddress][1] if byte[bufferAddress][2] == "S" d:= 1 else d:= 0 "D" : w := 5 i := byte[bufferAddress][1] 'd := str2dec(bufferAddress + 2) "S" : w := 6 i := byte[bufferAddress][1] 'd := str2dec(bufferAddress + 2) ''# # ''# # ''# These methods are for compatibility, they are commented out to save space. If you need them, un-comment them. # 'PUB VERBOSE(mode) | m '' Sets Verbose (Command Echo) mode "ON" (1) or "OFF" (0), Returns mode or false if incorrect mode is given ' if mode == string("ON") or mode == 1 'if mode is set to "ON" or "1" ' m := 1 'set m to 1 ' elseif mode == string("OFF") or mode == 0 'if mode is set to "OFF" or "0" ' m := 0 'set m to 0 ' else 'else ' result := -1 'set result to -1 ' return 'and return to caller ' 'result := m 'set result = m 'LCD_CMD1(vrb,m) 'send "Verbose" command to display with mode as paramater 'serial.rxflush 'call rxflush 'PUB REM '' Remark? 'PUB COMMENT 'PUB ERASE(namePointer) '' Delete file name @ namePointer ' LCD_STR(58,namePointer) 'send "DELETE" command to display 'PUB TYPE(namePointer) '' Sends the content of the file name to the current console port ' serial.tx(59) 'send "TYPE" command to display 'PUB CHDIR(directoryNamePointer) '' Change to directory ' LCD_STR(52,directoryNamePointer) 'send "CHDIR" command to display name @ directoryNamePointer 'PUB MKDIR(directoryNamePointer) '' Make directory ' LCD_STR(53,directoryNamePointer) 'send "MKDIR" command to display with "name" @ directoryNamePointer 'PUB RMDIR(directoryNamePointer) '' Remove directory ' LCD_STR(54,directoryNamePointer) 'send "RMDIR" command to display 'PUB SET_CMD(interfacePointer, baud, cmd, modebitsPointer) '' Select command to interface. Baud rate = 110 to 230400. com = 1 for command port. mode = "n91/2" : "O81/2" : "N81/2" ' serial.dec(62) 'send "CMD" to display ' serial.tx(32) 'send "space" to display ' serial.str(interfacePointer) 'send "interface" @ Pointer to display ' serial.tx(32) 'send "space" to display ' serial.dec(baud) 'send "baud" to display ' serial.tx(32) 'send "space" to display ' serial.dec(cmd) 'send "cmd" to display ' serial.tx(32) 'send "space" to display ' serial.str(modebitsPointer) 'send "modebits" @ Pointer to display ' CR_LF ''# # ''# # ''############################################################################################################################################# ''# # ''# Public functions for reading data from screen # ''# # ''############################################################################################################################################# PUB RXFLUSH '' Used to flush fullDuplexSerial Recieve buffer serial.rxflush 'call rxflush PUB RXCHECK '' Return character in FullDulexSerial buffer result := serial.rxcheck 'call rxcheck and return result PUB RXWAIT '' Wait for FullDuplexSerial character result := serial.rx 'call rx and return result PUB GetString | n,co,c ''pass string to buffer in main memory and set result to string size n := 0 'clear "n" repeat while (c := serial.rx) <> LT and n <> buffersize - 1 'repeat until line terminator or buffer full , read byte from serial.rx to c incoming[n++] := c 'store c in incoming buffer and increment "n" ' n == buffersize NG no line terminator found within max length ' n < buffersize OK but may still be missing numbers if n < buffersize - 1 'if buffer not full incoming[n] := 0 'terminate string with 0 repeat co from 0 to n 'repeat "co" length of string byte[bufferAddress][co] := incoming[co] 'copy byte from incomming buffer to buffer in main memory result := n 'set result to string size else 'if buffer full result := -1 'return -1 ''############################################################################################################################################# ''# # ''# Private functions for sending data to and from screen # ''# # ''############################################################################################################################################# PRI LCD_D_S(cmd,dec,stringPointer) '' Send a command, 1 decimal and 1 string to display serial.dec(cmd) 'send "cmd" command to display serial.tx(32) 'send "space" to display serial.dec(dec) 'send "index" to display serial.tx(32) 'send "space" to display serial.str(stringPointer) 'send fontName @ Pointer to display CR_LF 'send CR + LF to the display PRI LCD_STR2(cmd,stringPointer1,stringPointer2) '' Send a command and 2 string parameters to display ' MASTER_STR(@cmd, 2) serial.dec(cmd) 'send "cmd" command to display serial.tx(32) 'send "space" to display serial.str(stringPointer1) 'send first string to display serial.tx(32) 'send "space" to display serial.str(stringPointer2) 'send second string to display CR_LF 'send CR + LF to the display PRI LCD_STR(cmd,stringPointer) '' Send a command and a string parameter to the display ' MASTER_STR(@cmd, 1) serial.dec(cmd) 'send "cmd" command to display serial.tx(32) 'send "space" to display serial.str(stringPointer) 'send string to display CR_LF 'send CR + LF to the display PRI LCD_CMD4(cmd,dec1,dec2,dec3,dec4) '' Send a command and 4 decimal parameters to the display ' MASTER_DEC(@cmd,4) serial.dec(cmd) 'send "cmd" command to display serial.tx(32) 'send "space" to display serial.dec(dec1) 'send dec1 to display serial.tx(32) 'send "space" to display serial.dec(dec2) 'send dec2 to display serial.tx(32) 'send "space" to display serial.dec(dec3) 'send dec3 to display serial.tx(32) 'send "space" to display serial.dec(dec4) 'send dec4 to display CR_LF 'send CR + LF to the display PRI LCD_CMD3(cmd,dec1,dec2,dec3) '' Send a command with 3 decimal parameter to display ' MASTER_DEC(@cmd,3) serial.dec(cmd) 'send "cmd" command to display serial.tx(32) 'send "space" to display serial.dec(dec1) 'send dec1 to display serial.tx(32) 'send "space" to display serial.dec(dec2) 'send dec2 to display serial.tx(32) 'send "space" to display serial.dec(dec3) 'send dec3 to display CR_LF 'send CR + LF to display PRI LCD_CMD2(cmd,dec1,dec2) '' Send a command with 2 decimal parameter to display ' MASTER_DEC(@cmd,2) serial.dec(cmd) 'send "cmd" command to display serial.tx(32) 'send "space" to display serial.dec(dec1) 'send dec1 to display serial.tx(32) 'send "space" to display serial.dec(dec2) 'send dec2 to display CR_LF 'send CR + LF to display PRI LCD_CMD1(cmd,dec) '' Send a command with 1 decimal parameter to display ' MASTER_DEC(@cmd,1) serial.dec(cmd) 'send "cmd" command to display serial.tx(32) 'send "space" to display serial.dec(dec) 'send dec to display CR_LF 'send CR + LF to display PRI LCD_CMD(cmd) '' Send a command to the display serial.dec(cmd) 'send "cmd" command to display CR_LF 'send CR + LF to display 'PRI MASTER_DEC(cmdPtr, num) | idx ' serial.dec(byte[cmdPtr]) ' repeat idx from 1 to num ' serial.tx(32) ' serial.dec(byte[cmdPtr][idx]) 'CR_LF ' 'PRI MASTER_STR(cmdPtr, num) | idx ' serial.dec(byte[cmdPtr]) ' repeat idx from 1 to num ' serial.tx(32) ' serial.str(byte[cmdPtr][idx]) 'CR_LF PRI CR_LF '' Send CR + LF to the display serial.tx(13) 'send CR to display serial.tx(10) 'send LF to display {{ ┌──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │ │files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │ │modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│ │is furnished to do so, subject to the following conditions: │ │ │ │The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │ │WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │ │COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │ │ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │ └──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ }}The problem is: Returns from this workPUB LIGHT(brightness) '' Set backlight level to brightness when 0 - 100 (as percent) *default is 75%. If brightness = -1, returns the current brightness as ASCII 0-terminated STRING to buffer in main memory if brightness > -1 and brightness < 101 'check to make sure brightness is between 0 and 100 (as percent) LCD_CMD1(bri,brightness) 'send "LIGHT" command to display with brightness elseif brightness == -1 'if brightness = -1 LCD_CMD(bri) 'send "LIGHT" command result := GetString 'pass string to buffer in main memory and set result to string size ' *** Tested OK *** '_________________________________________________________________________________But this does not return anything?PUB COLOR(CID) '' Set current color to COLORID (0 - 199). If CID = -1, Returns current color to buffer in main memory and set result to string size. Returns 0 if good, -1 if incorrect color is given if CID < 200 and CID > -1 'if CID = (0 - 199) LCD_CMD1(col,CID) 'send "COLOR" command to display with "c" elseif CID == -1 'if CID = -1 LCD_CMD(col) 'send "COLOR" command to display result := GetString 'pass string to buffer in main memory and set result to string size else 'otherwise result := -1 'set result to -1They should either both work, or neither. Why one works, and the other one doesn't has me confused. Any help would be appreciated as always!http://www.parallaxsemiconductor.com/goldstandard
For your question, if CID<200 and CID > -1 then there is no assignment to result? Your first example is also missing such an assignment, but perhaps you don't have a test case for the first condition.
about the assignment, if CID<200 and CID > -1, then you are writing CID to the display, setting the display to use that color. Same thing with the backlight. If you send your setting the backlight to 80%. If you send this should return the current backlight setting and place it in BacklightSetting. *and does, in a round about way returning the SIZE, and placing the actual value in the buffer* does NOT behave properly and returns 0, or no string? The command seems to be getting lost, but seems to work everywhere else it's used. I'm just scripting the RETURN sections of the code now. You can send data to the display with what I posted, but getting data from the display *by calling the same method with the first parameter set to -1* is proving more difficult than anticipated!
Thanks again and I will keep you updated!
