Can someone help me! Boebot (photoresistor+IR Sensor)
Duhitpt
Im currently stuck on this project, So far i got the Photoresistor to avoid black line using deadband. But I cant seem to work the IR sensor to avoiding object. can someone help me please. My project is similar to this video, so far i got through the first two maze, but last one doesnt work http://www.youtube.com/watch?v=i8gghvQbs-g&feature=relmfu
' {$Stamp bs2} ' Stamp Directive.
Declarations
irDetectLeft VAR Bit
irDetectRight VAR Bit
left_photo VAR Bit
right_photo VAR Bit
pulseCount VAR Byte
counter VAR Nib
Initialization
OUTPUT 2 ' Set P2 to output.
FREQOUT 2,4 2000, 3000 ' Program start/restart signal.
LOW 12 ' Set P12 and 13 to output-low.
LOW 13
Main Routine
Do
FREQOUT 7, 1, 45500
irDetectLeft = IN8
FREQOUT 1, 1, 45500
irDetectRight = IN0
' Measure RC time for right photoresistor.
HIGH 3 ' Set P3 to output-high.
PAUSE 3 ' Pause for 3 ms.
RCTIME 3,1,right_photo ' Measure RC time on P3.
' Measure RC time for left photoresistor.
HIGH 5 ' Set P5 to output-high.
RCTIME 5,1,left_photo ' Measure RC time on P5.
' Check if difference between RC times is within the deadband, 2 in this case.
' If yes, then forward. If no then skip to check_dir subroutine.
IF ABS(left_photo-right_photo) > 2 THEN check_dir
forward_pulse:
PULSOUT 12, 1000
PULSOUT 13, 500
PAUSE 20
NEXT
IF (irDetectLeft = 0) AND (irDetectRight = 0)THEN
GOSUB Back_Up ' Both IR pairs detect obstacle
GOSUB Turn_Left ' Back up & U-turn (left twice)
GOSUB Turn_Left
ELSEIF (irDetectLeft = 0) THEN ' Left IR pair detect
GOSUB BACK_UP ' Back up & turn right
GOSUB Turn_Right
ELSEIF (irDetectRight = 0) THEN ' Right IR pair detect
GOSUB Back_Up ' Back up & turn left
GOSUB Turn_Left
ELSE ' Both IR pairs 1, no detects
GOSUB Forward_Pulse ' Apply a forwards pulse
ENDIF ' and check again
LOOP
check_dir:
IF left_photo > right_photo THEN right_pulse
IF left_photo < right_photo THEN left_pulse
Subroutines
left_pulse: ' Photoresistor
PULSOUT 12, 500
PULSOUT 13, 500
PAUSE 20
NEXT
RETURN
right_pulse: 'Photoresistor
PULSOUT 12, 1000
PULSOUT 13, 1000
PAUSE 20
NEXT
RETURN
Forward_Pulse: ' IR Forward
PULSOUT 13, 850
PULSOUT 12, 650
PAUSE 20
RETURN
Turn_Left:
FOR pulseCount = 0 TO 20 ' IR Left turn
PULSOUT 13, 650
PULSOUT 12, 650
PAUSE 20
NEXT
RETURN
Turn_Right:
FOR pulseCount = 0 TO 20 'IR Right turn
PULSOUT 13, 850
PULSOUT 12, 850
PAUSE 20
NEXT
RETURN
Back_Up:
FOR pulseCount = 0 TO 40 ' IR Back up.
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
RETURN
Declarations
left_photo VAR Bit
right_photo VAR Bit
pulseCount VAR Byte
counter VAR Nib
Initialization
LOW 13
Main Routine
Do
FREQOUT 7, 1, 45500
irDetectLeft = IN8
FREQOUT 1, 1, 45500
irDetectRight = IN0
forward_pulse:
PULSOUT 12, 1000
PULSOUT 13, 500
PAUSE 20
NEXT
GOSUB Turn_Left
GOSUB Turn_Right
GOSUB Turn_Left
LOOP
check_dir:
Subroutines
PULSOUT 12, 500
PULSOUT 13, 500
PAUSE 20
NEXT
RETURN
PULSOUT 12, 1000
PULSOUT 13, 1000
PAUSE 20
NEXT
RETURN
PULSOUT 13, 850
PULSOUT 12, 650
PAUSE 20
RETURN
Turn_Left:
PULSOUT 13, 650
PULSOUT 12, 650
PAUSE 20
NEXT
RETURN
Turn_Right:
PULSOUT 13, 850
PULSOUT 12, 850
PAUSE 20
NEXT
RETURN
Back_Up:
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
RETURN
