Can other types of antennae be attached to the Xbee modules?
Considering the types of Xbee modules that use the little whip antennae: I was wondering if those antennae can be detached and if other types of antenna can be attached. For example, if you have a robot in which you'd like to bury your electronics deep inside a metal housing, could you hook up something that would position the antennae on the outside of the housing?
Thanks.
Thanks.
or a reverse SMA (RPSMA), which is a lot bulkier.
You'll notice the PCB has pads for several different antenna types.
You could solder on an U.FL connector and run a shielded coax wire to an antenna on the outside of your bot.
If you modify an XBee to use an external antenna, you will also have to remove whatever antenna is already on it.
Thanks, Phil. Thanks again Duane. I think I'll just work with the Parallax stuff for now until - and unless - I absolutely need something else. From what I've read, their radio signals can still get through a plastic housing (as opposed to a metal one) so perhaps a plastic housing is all I really need.
Thank you, gentlemen, for your insights on this. Much appreciated.
Thanks for the heads-up on that.
