Basic Stamp Project execution problem
migudono
I have a project with Datalogger, a timer and temperature Test chip (each 20 second, the project test the temperature and the program save info in a file with datetime field and temperature field, that´s all)
Well, when I run the code from the aplication, he run OK reporting via debug the temperature tested and the succesfull writed in Datalogger, BUT when I disconnect the cable, he runs ok by 1 or 2 minutes only, and then stop.....
I disabled the debug report thinking the debug needs the cable connection, but Stop anyway
Looks like the project always need the cable conecction
A suggest?
Sorry my bad english, I'm spanish speaker from South america
A suggest?
I'm using a 4gb pendrive. I don't remember if datalogger is limited to some size of pendrive
month ago here comment me that datalogger only write 8,3 file name format, for example
I try switching once and twise, pressing reset button too....with the same result...
recently I changed the pendrive
first I used a generic 4gb pendrive
then i tried with old 512kb kingston pendrive with the same results
Finally I used an ol 512kb memorex pendrive and run ok since a couple of hours... I don't know why...
thanks
I will change the conversation to solved...
