Reading 8bit ADC in parallel
Hello,
I would like to have a question about ina register in propeller, Basically I am using a development board.
What I am trying to do in assembly is to read 8bit ADC value in parallel at a 7mhz rate. the code is attached.
In a new cog, it just is keeping reading ADC and storing each into designated address.
In the other side, spin code is getting the stored ADC values and sending them to PC in order to check through the serial port.
But I haven't gotten any right value from this program except for zeros.
In addition, I tried to read ADC at a fixed address but it was the same as the previous one.
I read through the manual, but it is talking about the OUTA rather than INA.
I hope to see if my code works or not and to know how to set up to read ADC in parallel with an example.
Thank you for your help.
adc_asm.spin
adc_asm.spin
spin
2K
DAT org 0 mov dira,pin_mask 'set pins from 0 to 7 as 8 bit inputs start mov t0, par 'receving the first address of storage that adc values are stored to add t1, #100 't1 is counter for repeating this sequnce 100 times ''' t1 is undefined here - the res directive does not zero its contents, use MOV not ADD :loop mov t0, ina 'reading pins from ina register add t0, #4 'Increment with 4 because a long space takes up 4 bytes. ''' are you trying to use hub ram? You need to use WRBYTE and then ADD by 1 since adc is byte array djnz t1,#:loop 'after subtracting 1 from t1, it jumps to :loop until t1 gets zero mov t0, par 'setting t0 to the initial address of the storage jmp #start 'going back to first sequence right after 100 repition. t0 res 1 'temporary space for addressing as a pointer t1 res 1 'temporary space for counts. pin_mask long 111111_11111111_00000000_00000000Something more like this?
:loop mov t, ina wrbyte t, t0 add t0, #1 djnz ...The PASM loop is going to run much much faster than SPIN can keep up, so expect the whole adc array to be updated many times for a few SPIN lines...
