Could use some direction
Greetings: I have been interested in the Propeller for a little over two years now and finally bought the 130-32305 Educational kit to get started with the Propeller Processor. The reason for my choosing this kit was budget concerns. Now I need to figure out what I need to acquire to get a setup working for programming the chip and etc. I could not find a USB kit for a breadboard (at Parallax) and I am not sure what I need in this realm. I want to build a good setup to "play" with the processor and I am considering that I will be on LInux for my OS (or MacOS X) most of the time, though I am able to use an older P4 and might have access to WinXP for software.
I am a Amatuer Radio Operator (KD0JXP) and have a few ideas for using the Propeller... but mainly, I am seeking to do elementary stuff (like blinking LEDs and running a Serial LCD display) for the time being.
Any help on what I need to get this kit working is appreciated. Sorry for the newbie-ishness of this post, but I am new to embedded design in any event -- and you have to start someplace :-)
Hope someone can help! Thanks. Mike
Good luck.
Richard
G3CWI
Post edit: The Prop Stick seems surprisingly costly compared to the Quickstart board.
Using the kit that you referenced, you can use a USB plug to talk to the Propeller through a USB connection ... http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/398/Default.aspx?txtSearch=USB+Propeller
There are free software downloads here for various platforms located here ... http://www.parallax.com/ProductInfo/Microcontrollers/PropellerGeneralInformation/PropellerMediaPage/tabid/832/Default.aspx
Personally I have a native Linux boot machine running VMware to run windows, but that's just my preference. I think others have been successful running Wine, or BST directly.
I recommend putting the propeller and the EEPROM-chip into sockets with turned contacts that are mechanical robust before plugging them into a breadboard.
something like this http://www.reichelt.de/?ACTION=13;PIC=1;ARTID=8223;WIDTH=150;HEIGHT=150;SID=11T4cJLX8AAAIAAB@D6eo6ab35e29aeb020e43edc060fbf84a951
those ones have mechanical weak contacts (like the chips themselves)
http://www.reichelt.de/?ACTION=13;PIC=1;ARTID=8220;WIDTH=150;HEIGHT=150;SID=11T4cJLX8AAAIAAB@D6eo6ab35e29aeb020e43edc060fbf84a951
I would add current-limiting resistors of 150 Ohm to each Propeller-IO-pin. Prop-IO_pin----150 Ohm
LED or whatever device using 3.3V
If you make a shortcut accidently between an IO-pin to Vss or ground or between two IO-pins one
at 3.3V the other at 0.0V the resistor will limit the current to 20 mA which is a save value. I made several boards like this and they are working fine.
For programming you need some kind of USB-to-serial-adapter with the serial-side at voltage-level 3.3V.
prop-plug http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/398/Default.aspx?txtSearch=usb+to+serial
If the serial LCD is a 5V device you have to insert a current-limiting resistor too. But as you have a propeller-chip with 32-IO-pins in hands.
coding your own LCD-driver or using one from the http://obex.parallax.com/ that can be connected to a non-serial LCD will save you 10 bucks
(for the serial to LCD-controller-logic) http://www.sparkfun.com/products/255
http://obex.parallax.com/objects/search/?csrfmiddlewaretoken=5883f1b68a6c4bfe594b9af640a11029&q=44780
best regards
Stefan
Are you saying you did not get a prop plug, and this is the USB kit for bread board?
If you don't have prop plug, or USB, you make the serial port interface circuit.
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/SerialtoPropeller.pdf
Options are - Make a serial interface; buy a USB to serial "prop plug"
Or you can get a prop Quickstart board, that is an easy way to get going.
Thanks for the help so far and indeed, I am sure we will be seeing more of me in this forum :-)
Have a good day all!
