Battery talk
I just recharged my new Tenergy battery packs with my new Li-ion Boe - Bot Power Pack Charger (7.5 Vdc, 1 amp adapter). I got a cell fault indicator on one of the cells. I reset it three times and continued to get the fault so I replaced the offending cell with anoter one (I bought 4) and all went well. Does this mean that the offending cell is defective or is it a quirkie kind of deal with those cells?
The Power Pack Charger was designed using normal (unprotected) Li Ion batteries. The protected Tenergy cells sometimes don't get along with the charger.
There are two ways I'd try getting the battery to work. One (preferable) would be to discharge it to a lower charge state.
The other way (I'm not so sure about) would be to charge it a bit by some other means. If you could give the battery about 500mA at 4.4V for about ten minutes, it might move the battery out of the zone that causes the fault.
I used the charging technique with a LiPo pack that wouldn't charge with a different charger until I had recharged the low cell first with a bench supply. I don't think I've tried it with a Li Ion battery.
Just so you know. Batteries (Tenergy) I initially had trouble charging, started behaving better after a couple of discharge and charge cycles.
-- Gordon
Gordon,
Do you have any suggestions on how to test them? I purchased six of the Tenergy cells from Parallax and several of them didn't seem to like the Parallax charger. I'm pretty sure they all work now but I haven't been keeping track of which ones have been used and which haven't.
Any idea how to tell a reluctant cell from a bad one?
Sorry, no. All of the ones I've gotten (not that many, maybe a half dozen) have all worked. The cells from Parallax are the ones with PCBs in them, no?
MattG is the LiPo expert, and by no coinkidink, the expert on the charger as well. He'd be the best to ask.
-- Gordon
In any case I turned in a tech ticket with Parallax and I am waiting to see what I need to do.
Yes, these are the ones from Parallax with the PCBs. Matt mentioned he hadn't used the PCB batteries when he designed the charger. I know I'm not the only one who had some trouble with the PCB batteries working with the charger. I'm not sure if this was ever resolved.
It doesn't matter much to me now. I don't think I've had a problem with any of the cell misbehaving lately.
I bet one of your LiPo chargers would charge the Li Ion battery. The chemistries are pretty close. Some of those LiPo chargers have a Li Ion option (I think mine does, I'm also a R/C heli fan).
You wouldn't need to charge the battery all the way with your LiPo charger, just enough to get it out of its present state (I'm not sure about this).
Or try discharging the cell a bit. Many LiPo chargers also have a discharge feature.
I hope you let us know what Parallax says about it.
P/N 28987. I bought them from Parallax along with the charger and adapter. Look on your Web site ;-)
I’m pretty sure you can pull up the invoice by my E-Mail or maybe someone in sales could do it? I’ll go look and see if I can find the box that the stuff came in.
Sent: Thursday, April 26, 2012 3:25 PM
To: smithdavidp@yahoo.com
Subject: [SUPPORT #XSC-761-25008]: Defective Tenergy Cell
Hello,
We don't have any Tenergy batteries for sale. What part number are you referring to?
Please PM me with your shipping address.
I think we're in the process of getting cells from a different supplier, so that may be the issue- sorry you're getting bad data...
edit: although, with that part number, the tenergy cells come up...odd - "Heads Shall Roll" in the mornin'!
-MattG
As you know, the charger pack also has a 2 amp fuse to prevent too great of a discharge rate. This is in addition to the internal discharge current limiting circuit internal to the cells. Therefore, given my druthers, I prefer the "un-protected" cells, but for liability sake, we went with "double-protection without representation"- or something like that. Feel free to use un-protected cells in the Packs.
Duane's suggestion: is preferable than the "other method" :thumb:
-MattG
I modified the cell holders to make changing out the cells easier. On one I cut off both the "wings", It makes removing cells very easy yet they seem to be very secure. On the other, I removed one "wing" from each holder. It is still fairly easy to remove the cells and there is no way it is coming out accidentally, short of throwing it against a wall.
I salvaged six cells from a Dyson battery pack that no longer functioned in the vacuum. After running them through the charger they all are working fine. I think at least one cell must be bad, but so far I cannot determine which one. I also intend to salvage some cells from a couple laptop batteries.
Note that if you do salvage cells to be careful to insulate the positive end, so that you cannot short it during handling or installing in the holders.
I have already blown a 2 amp fuse. I have one mounted to a Stingray, when the motors stalled, a few seconds later the fuse blew. 2 amps seems to be on the conservative side, what is the real max current that is safe to draw?
Some Cells that have PCB built-in protection have an internal fuse that blows if you draw too much (to protect the cell). Since this charger can work with both protected and un-protected cells, we erred on the side of caution by putting an external fuse on the Board. That way, the *cheap* fuse blows, but the protected cell's internal fuse does not. So feel free to put a larger rated fuse in there (especially if you're using un-protected cells) if you'd like - at your own risk. Remember though there's going to be an upper limit to the amount of current that can flow through the PCB traces. Lots of amps to be sure, just be careful...
I've even used a penny for a fuse jumper - no strike that - I've never done that, nope not me
-MattG
If you feel the cell is safe then I will go ahead and use it. I'll just keep an eye on it when charging. But I am curious about one thing though. If the charger trips a Reset Fault, will it continue to charge the cell?
-MattG
Just to let you know I have requested a new Cell from Matt. I will be shipping the defective cell either to him directly or Parallax in general. Waiting on my E-Mail reply from Matt.
I haven't received a PM (Private Message) or an email from you yet. I just PM'd you, but if you prefer, you can email me directly: mattg@parallax.com
I'd like to send you a new cell, but I need to know where it should go
-Matt
