BS1 = Output Pin HIGH and LOW actual voltage range
Hello, I tried to find this on the Parallax web site. Could someone please tell me the BS1 actual voltage range for an output pin for HIGH and for LOW? I need to connected a reed relay directly to the pin and also need to know how much current the pin can handle (limiting resistor). The voltage ranges will let me select the relay with the correct dropin and dropout voltage.Thanks.
PS: A BS2 can SINK 25 mA to ground. Comes in handy sometimes.
can be driver directly off a BS1 pin. No resistor, but use a flyback diode, per http://www.kronosrobotics.com/Anotes/Relays.pdf
Note that a BS1 Project Board will NOT work, since it has built-in 220 ohm protection resistors that limit current. If you want to use a Project board, you will need to add a small transistor to switch a relay, or else you can use a larger transistor to drive the load directly and eliminate the relay entirely.
