using the BOE Shield
I have a question regarding this shield. I want to use it and its 5V power regulator to power small DC hobby motors. I'm wondering where to connect the two wires from the motor. Do they just go in one of the 10, 11, 12, 13 "servo" pins? PS: This is the Shield for the Arduino. Thanx
Remember that the 5V regulator can only supply 1A for everything including the Arduino board. Make sure the motors don't draw too much.
To control the speed and direction of a DC motor you would want to buy either the Ardrumoto shield, the classic Arduino motor shield, or the Pololu motor controller Parallax sells. Relays can also be used, but that is more advanced.
I can see that I'll need a motor control shield to power beefier DC motors (not to mention H bridges for directional control).
Thanks Mr. H. for mentioning the bit about the available shields.
