Spin Help
Hello,
I am working on a homemade ping sensor just for fun and experimentation for my students. I am using two 40khz side-by-side ultrasonic transducers. To amplify the receiving signal, I am using an op amp breakout board from spark-fun. The hardware and software are below:
I am not getting anything to the serial terminal. When I test each section (tx and rx) I get a nice pulse from the tx and out of the amp I get a 2vpp signal or greater (3vpp max) (sinewave).
Thank you,
Cenlasoft
* USTXRX.spin V1.1 *
* Author: Curtis Desselles *
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
Long Exp_Val, Stack1[32]
OBJ
pst : "Parallax Serial Terminal"
PUB Main
pst.start(115200)
pst.Clear
pst.Home
repeat
Exp_Val := US_out(0,1)
pst.dec(Exp_Val / (clkfreq / 1_000_000))
pst.NewLine
PUb US_out(fpin,BT_Pin) : Time_Num | t, us, cnt1
'' US pulse generator
'' -- uses ctra to modulate pin at 40kHz
us := clkfreq / 1_000_000
dira[BT_Pin] := 0
ctra := (%00100 << 26) | fpin
frqa := 2_147_483 ' 40kHz @ 80MHz system freq
dira[fpin] := 1
t := cnt ' Get the clk count
outa[fpin] := 0 ' allow modulation
waitcnt(t += (clkfreq / 1_000_000 * 125)) ' on 125 us
outa[fpin] := 1 ' kill modulation
waitpeq(0, |< BT_Pin, 0) ' Wait For Pin To Go LOW
waitpne(0, |< BT_Pin, 0) ' Wait For Pin To Go HIGH
cnt1 := t ' Store Current Counter Value
Time_Num := t - cnt1 ' Store Time_Num value
Thank you,
Cenlasoft
Maybe if you explain intended function of the code.
waitcnt(t = (clkfreq / 1_000_000 * 125)) ' on 125 us
I think the "=" sign is not correct. Did you mean to have it as:
waitcnt(t + (clkfreq / 1_000_000 * 125)) ' on 125 us
I will explain the purpose of my code. First, when I set up the hardware and use the scope to monitor the signal, I get a sine wave of about 360 mvpp with no obstruction to bounce back on. When there is an obstruction to bounce back, I get a 1- 3vpp signal depending on the distance of the obstruction. I was planning on sending a pulse (125usec at 40khz) and then wait for a low and then a high then low again to give me the time of flight. I could have ran the tx portion in a separate cog with an interval of about 1ms and use that time to wait for a signal. What is the best way to wait for the signal echo? Is my op amp breakout board slowing things down? Beau had suggestion on another post to use sigma-delta to measure the time of flight and stated that the procedure would amplify also.
Cenlasoft
