Waterproofing the basic stamp — Parallax Forums
jst97610jst97610 Posts: 4
edited 2012-04-24 23:00 in BASIC Stamp
Hello Fellow Stampers,
I am working with an industrial application of the basic stamp which will require it to enter a very wet environment. I was curious if anyone had ran across a good off the shelf option for protecting the stamp in such environments. Any information you could provide would be great. Thanks in advance.
    edited 2012-04-23 15:47
    Look for housings rated to NEMA 4X or IP65. You will also need to provide waterproof connectors or cable glands for any external connections.
  • xanaduxanadu Posts: 3,347
    edited 2012-04-23 16:34
    Easy off the shelf product would be a Pelican Case, and some waterproof connectors for anything external.
    Or just send it here - http://www.liquipel.com/ LOL...
    edited 2012-04-23 23:55
    http://www.polycase.com/waterproof-nema-gasket
    I like the WC series because of the clear tops.
  • eiplannereiplanner Posts: 112
    edited 2012-04-24 03:52
    Would there be heating issues with the stamp circuit board if it were simply dipped in varnish?
    edited 2012-04-24 22:59
    eiplanner wrote: »
    I'd worry about the varnish attacking some of the components such as electrolytic caps.
    jst97610 wrote: »
    jst - have you considered "conformal coating"?
    http://en.wikipedia.org/wiki/Conformal_coating
    I've seen suppliers for spray-on and brush-on versions.
    BTW - welcome to the Forum!
