Now Available: Solid State "Relay" board - dual n-mosfet
tonyp12
Only 9 are available, your design input will be considered for second batch of 100 units.
To buy 1: ($8 + $2 shipping):
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=GJLVXFATEWEUQ
Specs:
Dual 7.8 Amp N-channel mosfet, max 20v (use at the low side of load, e.g complete the circuit to ground)
2.5v gate drive (max 12v), Direct connections to Propeller and Basic stamp.
20 Ohm smt resistors in series on gate to prevent ringing and the associated EMI.
User install if needed (supplied)
Pull Up or Down Resistor for a known initial state during boot up, or use with mechanical switches/photo transistors.
4 pin header.
Specs:
4 pin header.
